Old 03-27-2012, 02:11 AM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
JDM engine interchange
Hi!
Does anybody know, can i plug-and-play JDM engine to my USDM 1994 Lsi?
I know that JDM ECU is different, and there is no EGR on JDM,
so:
1. Will it works on USDM ECU if i plug all USDM gauges, exept EGR, to JDM engine?
2. Or i must plug all USDM gauges (include EGR) to JDM engine and only after that it will work?
Please help, it time to think about engine interchage because of knocking noise from crankshaft(
Thanks,
Gleb
Subaru SVX LSi `95
Old 03-27-2012, 05:30 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: JDM engine interchange
I have run a JDM engine on a Euro TCU before. It ran fine but gave an error code for faulty EGR system. I expect the USDM ECU will do the same.
You could either fit a JDM chip in your ECU, or fit the USDM EGR to the JDM engine.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
aust92pearl aust92pearl is offline
Originally Posted by Kiss Me Deadly View Post
Hi!
so:
Thanks,
Gleb
just use the bare jdm long block with all the usdm intake , sensors etc
is 1994 obd2 ?
it will throw egr code on obd2 but not 1 (i think ) imn sure someone more knowledgeable then i , will chime in to correct me
Old 03-27-2012, 06:52 AM
Thanks for replys!
I`ll think about all variants
Subaru SVX LSi `95
Old 03-27-2012, 11:46 AM
A 94+ USDM ECU will throw a code if it doesn't see an EGR temp sensor and solenoid (92-93 did not have the temp sensors, but will throw a code if the EGR solenoid is missing). It doesn't matter what the reading is, it just has to be physically plugged in. You could use the JDM engine, and just take off the intake manifold, swap the wiring harnesses, and plug in the EGR solenoid, and temp sensor. As long as they are plugged in and the EGR solenoid can move back and forth, it will function. Plug the lines on the EGR solenoid so it stays clean.
