ECU/TCU wire gauge
What is the gauge of the wires between the ECU and the TCU?
Re: ECU/TCU wire gauge
Without actually going to measure, Subaru generally uses 18 gauge wire for the most part. I would be surprised if it wasn't 18 gauge, maybe 16.
OK, thanks. It looks like I will need to buy both 14-16 GA and 18-22 GA wire taps.
