Old 10-28-2010, 01:53 PM
httrdd httrdd is offline
MAF Repair Question.
In this picture you can see there is the third pin with the solder missing. I am just checking if that is normal before I solder it up.
I was having stalling issues with the MAF and was told to put my LGT one on to check if there are other problems. I have not had a stall problem since the change out so I know the MAF was bad.
Here is a pic.
Old 10-28-2010, 03:20 PM
Re: MAF Repair Question.
All 4 get soldered. That is most likely the problem with it.
Here is the how to:
http://www.subaru-svx.net/forum/showthread.php?t=53957
Old 10-30-2010, 03:34 PM
Thanks man I found your thread. It worked like a charm. Drove the **** out of it and no problems yet!
Old 10-30-2010, 04:12 PM
Yeah it works, I had 2 go bad and repaired both of them by resoldering, which is surprising since I had never used a soldering iron before then.
