Need a clip visual reference for Diagnostics ports
In the midst of gutting the SVX harness for my WRX I removed the Select Monitor and Diagnostic ports from the harness, thinking that I wouldn't need them for this temp harness(going MS or Hydra in the near future)
I still have the plugs ports, but they're in a plastic shopping bag along with every other clip I cut/removed and don't know what they look like. can someone take a picture of the Select monitor and the Diagnostic port plugs and post them here for me to see? I'll just match up what you show there. This is a USDM car if it matters, not sure of euro stuff was different back then. Also can someone explain to me the diag process for pulling up PCM codes for these cars? I know there used to be two blue plastic covered wires under the dash that had long male pins on the end. According to the diagrams these are ground test leads. I have an OBD1 scan tool but likely not the right firmware and plug to adapt it to this car. any help would be greatly appreciated . I'm in dire need of getting this car running as snow is goign to be flyign here soon and I want my AWD back. thanks!!!! -Adam |
Re: Need a clip visual reference for Diagnostics ports
Hi Adam
There are already pictures of this in the How To section. Check: Electrical There are two documents. One is a PDF with pictures. The other is a copy from the manual showing what the codes read. If you need more than this shout. Joe
