overdrive problem ???
Didn't find this on a search, so :
My 96' when it shifts into OD pretty much starts to feel like the car is coming unglued. just starts shaking like crazy. as soon as I downshift to 3d, it all goes away. -I did get an error code for #5 coil but I can't for the life of me figure out how that would make the car go nuts only in OD. -trans acts fine otherwise. -Fluid was replaced 3 years ago along with timing belt, and i do a pan change each time I change the oil. -no burnt smell to trans fluid -car has only been driven 200 miles in the last two years, pretty much in (covered) storage while I was in Afghanistan and since I got home. thoughts ?
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
Re: overdrive problem ???
If you find any, scratch them out, and spray it with a silicon oil. If you don't find any, buy a new coil. Harvey.
Thanks Harvey- never would have figured a coil could cause the car to shake like that.
I got a complete set of extra coils just in case. once I get back to NY I will put one in and see how we fly. thanks again!
=D if your around here in NC it will take me 2 mins to pop that S.O.B out =D I just replaced mine... or was it #6... I don't recall lol Driver side nearest firewall.
probably head up in a few days. Also need to change out the rear bearing or HUB complete on my 95 I think I found a complete hub though. I HATE changing out those bearings.
ahh well if ya ever need an extra hand here in NC let me know !
OK, so I replaced what I thought was coil #5, driver side, the one closest to the battery. (based on the pic in my Chilton book.) no real change, and I still get error code P0305.
is #5 on the passenger side all the way n the front
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue Last edited by ssnsltd; 12-16-2008 at 02:27 PM. |
OK, in another pic the book shows # as passenger side, against the firewall.
should have known the forst pic was reversed by the way they had the igniter.
To close out this question/ thread:
A dying coil/ bad spark will make ones car shake violently when the overdrive kicks in. Never would have figured that. Got the opportunity to work on the car in 25deg weather- and replaced the #5 coil. The spark plug (iridium) although loose, had good coloring to it so I left it in. Car runs fine other than it has been mostly in storage 2 years so I have some rust on the brakes to work off. Just passed my NYS inspection Not the best weather to be driving in, but figure I should run a few tanks of gas through it before putting it back in the barn.
