help with a noise
ok i have this noise in the tranny, i put it up on the lift today and had my tech teacher look at it.. its like something broke loose in it and is hitting the transmission caseing. it shifts fine and dont slip or anything. i dont know what it could be?..... any sugestions?
Re: help with a noise
Does it do it randomly, or does it do it under specific conditions? I would drain the transmission (17mm plug on the pan, get a new sealing washer from the dealer) and drop the pan and make sure there isn't anything in there, if it's shifting fine, it might just be a loose bracket or something, but sure would suck for it to bounce up into the guts of the tranny and toast something.
I don't know if you can get a tube of Three Bond or not, check with your local Subaru dealer, since as far as I remember there isn't a gasket on the transmission pan, just goo. (Don't use silicone! If anything use a tube of "the right stuff" gasket maker if you can't get a tube of Tree Bond.) I'll get a PDF from the service manual and attach it, for removal of the pan. I just tried to get it but the site is being a pain in the arse...
ok ill do that before i pull the tranny out of it... thank you.. and it does it constiantly, it gets louder as i put on the gas.
Does it sound like a card in a Bicycle spoke ?
yea it does sound like a card in a bycycle spoke.....? i dropped the pan today and there was nothing in there....any other cuggestions before i tear the tranny out?
thanks bobby |
I could be wrong but ... The guru's on here will probably say the same.
how do i change that? does the tranny or anything have to come out?
its part of your front diff meaning your front differential is going bad.
i cant just change the pinion bearing?
