How do I remove centre tail light cover?
Preferably without destroying anything.
I feel a right twit asking, but I've searched and searched and can't find anything on it. The left hand side is sticking out enough to be (at least one) source of a boot leak. I can see the plastic thingies that look like they should fit snug beneath the trim, but either its jammed on the right or I just can't work it out. I'm scared to use too much force because of the electrics. Can anyone tell me how to remove it?
1992 Onyx SVX 184,500kms Now with new and improved no leak steering! No plants = no life on earth - so go forth and plant green things! |
Re: How do I remove centre tail light cover?
Actually, the above probably doesn't tell you what you really want to know. Its obvious that there are a couple of electrical connectors and the visible nuts. The harder part is getting the trim cover off the underside of the trunk lid without breaking the little mounting clips.
Carefully insert as screw driver under the edge of the trim piece and pry gently until you actually located the clip. Then in the area of the clip exert a slight pry pressure until the clip comes out of the mounting hole. there are clips all around the edge and then there is on nearly in the middle. That middle one is the trickiest. Gentle pry pressure will do the trick in most cases without any damage. A nice big flat blade screwdriver is best. I have done it this way 4 different times and only broken one clip. Lee
I didn't cover that very well in my writeup; thanks for the supplement.
Thanks guys. I could see the major clips and connections, but not all and couldn't figure if what I could see were all part of the same housing. The pics fill in the blanks and the trim cover explanation puts it all together.
I hope! Am going to give it a go today.... Tania.
Well I got the cover off and think I can see why it isn't seating properly, but I don't know if the goop is some kind of adhesive that's been applied in the past, or melted/degraded seals. The clips weren't really engaged at all - it was the goopy stuff that seemed to be holding it. All but the lower right came away easily. Clickable thumbnails;
Tail light bracket goopy stuff LHS; Tail light bracket goopy stuff RHS; Tail light bracket goopy stuff Middle; Tail light cover goopy stuff RHS; Tail light cover goopy stuff Middle: === Any suggestions? Thanks, Tania.
Apologies if resurrecting this annoys, but I've done my best to try and work it out by searching threads here and asking for advice from autoparts stores (and a rubber store). From threads etc I get where I need to check next if this doesn't turn out to be the only leak source, but I'm stuck on this atm. Will put everything I know/have done so I don't waste anyone's time.
As far as I can see from the parts diagrams, the only gaskets/seals are two behind either turn signal and two on each side of the centre light assy, while the light cover itself clips into the black plastic bracket, with no seal/gasket between . Aint so with mine - its the goopy stuff that's holding the cover on, not the clips - I can't even get the clips to engage because they're blocked by the goopy stuff buildup. I haven't found a clear diagram what clips are meant to be there but none are obviously broken, unless there's meant to to be one at the centre top. The goopy stuff seems to be either degraded u-channel or sealant. Maybe it isn't needed at all, or maybe it was put there to sort a leak in the first place and has become too degraded, so needs to be replaced. I don't know. I do know I need to scrape/clean it off to work it out, but... 1) If the clips don't turn out to hold it alone, what can I use to temporarily hold it while I work something out? Would some kind of silicone that I could peel off work? blu tac? tape of some sort? I'm awfully wary of the cover breaking. 2) If some kind of sealant replacement is needed, the only idea I've come up that would let me replace bulbs by taking off the cover & not having to remove the entire assembly is u-channel. If u-channel, would I try and fit it into the gap between the metal of the light assembly & plastic bracket, or on the cover itself (have asked places, but got conflicting suggestions)? Alternatively is there a selastic type product that won't permanently adhere? Thanks in advance, Tania. === If anyone else comes accross this in a search on leaks, here's a good thread link (that also links to another good thread): http://www.subaru-svx.net/forum/showthread.php?t=45943
hi tania i'd go the silicone(try neutral cure roofing type) route you can get it off later usually, i'm assuming you want to seal the cover to the housing? or is it the housing you want to seal to the bootlid?
cam ps im going to check mine out now lol all my lights get condensation in them |
shame about the water in the boot.... Quote:
Sorry, I'm not sure if you mean the silicone as a temporary solution, or a permanent one that would seal it but still let me remove the cover to change bulbs. Also, is the neutral cure type silicone so it doesn't damage the plastic? I was sold a tube of black 'gasket' silicone by an autoparts store, then told not to use it by the rubber place because its meant for high temp metal surfaces & would eat plastic/rust light metal. Thanks, Cam... so how are your covers? Tania.
you can get to the bulbs from the inside of the bootlid cant you? there is a movable flap on the inside of the bootlid cover
cam ps i didnt get the time i needed to fiddle with mine today but tomorrow for sure |
Only one option after all....
And I'm a twit - only realised I knew that after reading your comment.... So the only option is a fix that seals but won't permanently adhere. Started cleaning the goop today but with the panel in place. Guess I'm going to have to take the assembly out and see if there's a way of removing the metal bulb plate thingamy from the black plastic housing. Maybe that'll tell me more. Does anyone else have some kind of sealant/u-channel between the two? Cam, if you do do your lights tomorrow.....
