Old 08-03-2008, 12:06 AM
SLITHYTOVE SLITHYTOVE is offline
Question Code 37
Recently my 92 SVX has been intermittently running rough, usually when cold at idle, and more often when accelerating, I checked code and it gives error code 37 (lt sd o2 sensor). Could this be causing the problem? If so where is it located?
Thanks
Old 08-03-2008, 12:43 AM
kwren's Avatar
kwren kwren is offline
Re: Code 37
Thanks
It could be... but unfortunately it could not.
Located where the twin exhaust pipes come down from the motor and straightens out horizontally right below the transmission. Pretty easy to get to if you have a totally flat body or a floor jack and jack stand, and a couple of blocks for the rear wheels
There are 2 one for each side and I think 37 is the one on the left side. It is easily changed because the quick disconnect electrical connection allows you to disconnect the 02 wire connector and drop it down, slip a big box end wrench over the wires and screw it out. May need some kind of rust buster, but probably not!
Let us know if it works for you!
Keith
Old 08-03-2008, 08:02 AM
Wikedjuggalo's Avatar
Rebuilding
Re: Code 37
Keith
I'll second that rust buster :P needed some on mine and then it just screwed out nice and easy very simple job (once you find then connector :P)
