Old 06-05-2008, 08:53 AM
Schralper's Avatar
Schralper Schralper is offline
head milling
Ok I had this engine follow me home the other day.
So since my svx has 131K and running fine but I wanna do a complete rebuild and build a better stock-ish engine w/ this one.
How much can be safely milled from the heads to reduce combustion chamber size? I know my comp ratio is gonna go up, that's the idea.
I looked up my svx tech specs and can't find anything on max allowable head milling.
I plan on a mild port job along w/ new valvetrain pieces.
Gonna send out my extra set of injectors to get cleaned and flow tested, next week. I would like to get this engine done by early fall.
As I have another sbc (small block chevy) to build, oh joy
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 06-05-2008, 09:14 AM
Guys, do you have those in plastic or metal in your engines?
Old 06-05-2008, 09:16 AM
Danny, the earlier built engines had aluminum breathers, Head half moons, and seperator plates... The later engines had all plastic pieces...
Old 06-05-2008, 09:19 AM
The max cutting limit is .0118 Those are stock specs... Now if you plan on building this engine, you will want to take your own measurements once you have the cam profiles figured out to find out exactly how much you are going to be able to trim
Old 06-05-2008, 09:20 AM
Thanks for the info Tom
Old 06-05-2008, 10:00 AM
Schralper's Avatar
thanx
Only .010+"?
Sheesh, i was hoping i could shrink the comb chamber by a few cc's.
I plan on using stock cams, though I'm gonna degree'm.
I'd like to adv intake a couple deg. becuz of living @ 4200'.
Which is also the reason for more comp.
I don't have a chip or anything.
Figure until I get a free flowing exhaust it ain't gonna make much diff.
WFO!
Old 06-05-2008, 11:12 AM
kwren's Avatar
kwren kwren is offline
Keep in mind...
all you can do with a car is go some place in it.
Keith
Old 06-05-2008, 03:12 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Really??
Originally Posted by Schralper View Post
thanx
I live at 7500+ and all my cars do fine.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-05-2008, 11:29 PM
Schralper's Avatar
Lee
Yeah but they'd do way BETTER w/ more power
Since I don't have boost........
I guess I'll build me a nice eg33
WFO!
