Old 01-20-2008, 04:37 PM
danyvaly danyvaly is offline
found red thick cable beside battery cable
Hi:
q for a svx 94
I was replacing the battery, and when I conected the positive terminal with the positive cables(there's two cables), i found i thick red cable disconected that goes inside like a black box. Where does this cable go?
Also i had to change the baterry because all the acid came out... I use this car once every two months, the battery is like 3 years old, is this normal... or is it because of lack of use...i mean what provoked this?
Old 01-20-2008, 04:41 PM
Originally Posted by danyvaly View Post
Hi:
q for a svx 94
Can you post a link to a picture of the wire?
Old 01-20-2008, 04:45 PM
The acid came out of the battery? Is it all over the car, or did it evaporate? I haven't seen a battery go dry before. The battery in my SVX is 4+ years old, OEM Subaru, and the battery in my Taurus was over 7 years old when I replaced it. Never had an issue with fluid levels.
What kind of battery is it? (manufacturer?)
I can't help you with the wiring, but someone will jump on shortly.
Old 01-20-2008, 05:38 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
There should be a cable off of the positive terminal that goes into the fuse box under the hood.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-21-2008, 12:59 PM
red cable?
the cable goes into a box that says stinger, then there is a red button and then black lever that says reset. the cable is disconeected but seemd like the car works normally
battery acid, i'm located in miami probably was the heat???
Old 01-21-2008, 01:10 PM
I don't know too much about hi-power audio, but what you describe sounds a lot like a hi-power capacitor connector, maybe for some bigassed amp system that the last owner had pumpin bass yo.
Old 01-21-2008, 06:01 PM
Yeah that's a stinger brand breaker. They are easier to deal w/ than blown fuses in what would normally be a fuse block there.
blk 92' LSL w/ average mods
