Old 09-10-2007, 11:59 PM
kcpaz kcpaz is offline
Fuel system diagram needed
anyone know where I can find one?
Old 09-11-2007, 05:05 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Courtesy of JaySVX's signature: <click>
Old 09-11-2007, 07:45 AM
I looked through that, it's not in there...... onless I missed something.
Old 09-11-2007, 07:59 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Are you looking for the electrical or the plumbing?
Old 09-11-2007, 08:19 PM
I need plumbing, not wiring
Old 09-11-2007, 08:21 PM
in the engine bay??
Old 09-11-2007, 08:25 PM
yeah pretty much. The tank is just feed and return right?
Old 09-11-2007, 10:16 PM
Hocrest's Avatar
Hope this helps...
Old 09-11-2007, 10:28 PM
basically what I'm trying to figure out is why there are 3 fuel hoses coming out next to the intake manifold rather than just two. Are there 2 feed lines and one return, or 2 returns and 1 feed?
Old 09-11-2007, 10:33 PM
Hocrest's Avatar
From front to rear;
Fuel Supply -> engine (high pressure hose, screw clamp)
Fuel Return -> tank (high pressure hose, screw clamp)
Fuel Vapor -> cannister by ABS pump (fuel vapor hose, spring clamp)
Old 09-11-2007, 10:55 PM
what would happen if I caped off the vapor line (engine is going in a 911)? any negative affects on driveability
Old 09-12-2007, 09:43 AM
your tank cannot vent and will prob cause vapor lock unless you are plugging the engine side only
Old 09-12-2007, 08:08 PM
here's why I'm asking for a diagram. I'm building a custom fuel tank and the tank is going to have a vent, but the Porsche fuel system is obviously different than the Subaru system. I haven't decided if I'm going to be running any emissions controls so I'm not sure if I'm going to vent through a charcoal canister or just to the atmosphere. If I can pass a visual inspection without it, then I won't put it in. I just need to know how the Subaru system works so I can modify the fuel rails with AN fittings and fun the fuel lines in a way that will work with the engine controls.
