Old 08-18-2007, 08:43 PM
redlightningsvx's Avatar
Collision Refinishing Tech
possibility of awd conversion
I was wondering what parts things need to be done to make the FWD's to AWD and if it would be worth doing?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-18-2007, 09:08 PM
http://www.subaru-svx.net/forum/show...t=convert+ls-l
http://www.subaru-svx.net/forum/showthread.php?t=31966
Basically, AWD tranny, driveshaft, rear diff, axles, rear subframe, whatever other rear suspension parts are different. Probably an AWD trans control unit (TCU) and all the wiring needed to connect things. I'm sure I'm missing something though.
Old 08-18-2007, 09:13 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
It isn't too hard to do as you'll read. I have most of the parts to do it with, So just let me know if I can help with anything if you decide to do it.
Old 08-18-2007, 09:56 PM
The bigger issue is not the wiring in the trans itself... It is the wiring going from the TCU to the fusebox and then back to the TCU for the FWD fuse and whatnot... An mt fwd-awd swap is simple and very bolts basic. Not impossible and not even that hard... if you are good with a schematic and don't mind running some wiring
Old 08-22-2007, 12:58 AM
NiftySVX NiftySVX is offline
I just made a harness and put it in the left kick panel when i did it, it isn't that hard at all really. I spent alot of money on bolts, though. But then again, I bought factory ones.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-22-2007, 05:06 AM
Manarius's Avatar
Manarius Manarius is offline
If you're going to have the tranny out, you might as well just swap to 5MT as well....
-Jason
-Obi Wan Kenobi
Old 08-22-2007, 05:38 AM
JaySVX's Avatar
JaySVX JaySVX is offline
If you haven't done much to your car thus far, i would consider selling it and buying an AWD model. You'll probably end up paying about $1000 more than what you would be able to sell your FWD for, but that's parts alone for the awd conversion, not to mention the hours spent doing the swap.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
