Free range extender for Keyfob!
Alright, if you have a keyfob for your door locks for your svx, you know that you have to be practically inside the car for it to work. Well, once i got to texas, i met with a friend for lunch, and i picked up a neat little trick from him. I saw him unlock his car from like 50ft away, and iw as like wow, that's super range. He said nah, there's a special way to do it you get better range. I tried it and sure enough, 50ft away, i unlocked my SVX.
Open your mouth about an inch. Put the keyfob under your chin against the skin, and press the button. Be facing your svx though... THis changes your broadcast to a narrow band instead of 360degrees, and works great. Try different levels of mouth openness to adjust range if you have issues. Good luck in getting it to work. I'm sure some of you probably knew this, but for those who didn't, it's incredibly handy!
Been there, done that! Yes, it works.
yep, done it a hundred times - and if you are too far for that to work, put it in your mouth.
Affectionately referred to on the network as the "chin trick"
This has been posted here lots of times, it's even made it to autoblog:
http://www.autoblog.com/2007/06/01/v...ur-head-silly/ |
Am I the only one with a stock keyfob and security system that can open his car from 50 ft away without trickery?
i never knew that one. it's a neat trick
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
And 20 years from now we'll all have brain cancer
-Hump '99 RBP Subaru Impreza 2.5RS '92 Pearl White Subaru SVX - 136k - My first SVX -traded '92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible '92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine) Okay, so the bottom two cars don't actually exist but what if????? |
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
yea, that works. in my automotive tech class we found another cool trick if you leave your keyfob at home - this works on and off - and usually only with a cell phone that has an extendable antenna:
You can transmit the signal thru a cell phone from thousands of miles away to unlock the car by holding the fob up to the phone, while the other person holds their phone at the window. I didnt believe it until we tested it
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
I have discovered it also works at a 45 degree angle to the ground from far away even with a car parked in front of it.
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd |
Maybe a cheaper version of OnStar?
SUPER Extender
Bending over, dropping trou---------ooopss, don't think I better go there.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Holy crap. It DOES work.
Dangit, I know I had that flag around here somewhere...
