Old 07-19-2007, 12:58 AM
Trevor's Avatar
Trevor Trevor is offline
Engine Oil Level
The SVX dipstick has holes to indicate upper and lower levels, as well as a notch above the upper level hole. I have had another car with this same dip stick marking. What is the significance of the notch?
I no longer do my own oil changes and service people keep filling the crankcase up to the notch. Could this higher level than normal cause any problems in respect of crankcase breathing, seals, or whatever.
Advice would be appreciated from those who have hands on experience, in regard to bottom-end and the arrangement of the associated components.
Thanks in anticipation, Trevor *<)
Trevor, New Zealand.
Old 07-19-2007, 06:43 AM
JaySVX's Avatar
JaySVX JaySVX is offline
The difference is for engine temp.
The Middle notch is full when engine is cold, the top notch is full when the engine is hot.
The bottom notch is empty when the engine is cold, the middle notch is empty when the engine is hot.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 07-19-2007, 01:00 PM
There is a picture of the dipstick and it shows what the markings mean. It is shown here.
Old 07-19-2007, 04:40 PM
Trevor's Avatar
Thanks Earl,
If this data, so well set down, is not in the how too section, it should be.
I now know that my engine has been over filled, but as yet there is no comment as to whether this could cause a problem of any sort.
Old 07-19-2007, 08:38 PM
Originally Posted by Trevor
Thanks Earl,
It is in the How-To section under Engine, oil, oil level.
Old 07-19-2007, 09:56 PM
trevor... you know as well as I that a minor over filling of the engine will not cause any major distress... a major overfilling on the other hand... Thats asking for trouble
Old 07-19-2007, 11:22 PM
Trevor's Avatar
Thanks Tom,
I knew, but how could I be sure.
