Old 06-27-2007, 02:35 PM
Jvan Jvan is offline
Unhappy Ac Condensor Needed Urgently
ALWAYS SEEMS TO HAPPEN AT THE WORST TIME. tODAY WE HAVE A HEAT INDEX OF OVER 100 DEGREES AND THE AC CONDENSOR QUITS. aNYONE HAVE A SOURCE FOR A NEW CONDENSOR OTHER THAN THE DEALER? nEED ON AS SOON AS POSSIBLE TO GET THGROUGH THE SUMMER. dON'T REALLY WANT A USED ONE BECAUSE IT'S ALREADY 10 YEARS PLUS AND COULD GO ANYTIME. I HAVE A 94 BUT ALL SHOULD BE THE SAME. HELP! WIFE IS NOT HAPPY SINCE IT'S HER DAILY RIDE.
Old 06-27-2007, 03:07 PM
n00b on demand's Avatar
subaruparts.com
If you want a new one your only source is the dealer. If you want used then go to car-part.com or someone on the forum who is parting out an SVX. I wish I had one for ya since your close by.
Old 06-27-2007, 03:58 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Silly question: How do you know your condensor is bad? Is it leaking? Are you sure it's not something simpler like an O-ring where one of the pipes connect to it?
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
Old 06-27-2007, 06:01 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
I have one if you still need it. PM sent.
Old 06-28-2007, 09:21 AM
I had no cold air and went to a quick oil change place for a recharge on the system. The system was real cold for about 2 days and then no cold air. This time I took the car to my regular mechanic and he called to say that the condensor was bad. I didn't ask if he checked the o rings or where it was leaking. I'll ask him today to be more specific. I'll follow up with a pm when I know more today.
Old 06-28-2007, 07:41 PM
Question
the condenser is leaking from a seam not the o rings. I can't believe that Subaru produced a condenser specifically for the SVX since they have interchanagebility of parts with other models and other manufacturers. Anyone have any idea of how to check compatability from other manufacturers that might be available from aftermarket.
Old 06-28-2007, 08:13 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Maybe you can get other condensor that'll work with SVX, just have to make it work. Try to get something similar size and specs?
But how much is cost from Subaru or any other Auto part stores?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 06-28-2007, 10:22 PM
SVXdc's Avatar
At SubaruParts.com: 73210 (# on diagram) Condenser assembly 73020PA020 (part #) $251.42
David C.
