5 speed question
how much would a 5 spd cost to put in?
Jon 1992 Teal AWD SVX 10" Sub w/ Amp, Kenwood MP3 player 18" Rims To come: Shortram intake, repaint dash pieces, repaint random sections, clear lenses, refinishing leather...etc |
Are you talking about on your own or by a shop?
Nice! You might want to make the wording of the Ebay auction a little clearer. Do you really mean that a driveshaft for a 6spd is included in the price, but one for a 5spd costs $200 more? -Bill
#1...Who would be doing the work? you or a shop #2...what manual tranny are you going to use? (Impreza/Legacy 5-speed, WRX 5 or 6 speed ect.) #4... what kind of clutch package and flywheel do you want to use? #5...Custom parts, who is supplying / making them?you, or someone else? All these can make installing a manual tranny's cost vary greatly. The link in my sig is from the first documented 5-speed swap, which I did for under $1000...but I did all the fabrication, and labor myself, and bought cheap parts, since I wasn't sure if it would all work or not....but that car is still on the road (swapped in 2001) So you can do it on the cheap, or you can go all out and spend lots of money, just depends on what you want /or can afford. Hope this helps...
The 5mt extended driveshaft costs me $200 to have made (not an outback shaft) Tom |
Tom, I honestly didn't know that the stock driveshaft was a "plug-n-play" with the 6spd -Bill
since im looking for a quick answer :P what RANGE would you find a 6mt of any year in, and likewise for a wrx 5mt?
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
6mt's alone usually go for about 3k. wrx 02-03 for about 700 and 04+ for $1k
If you get the whole kit and kaboodle from an ebay seller or others expect to pay closer to 4-5k for a 6spd tom |
Do you retain cruise control once you've got to a manual transmission?
If wired properly....and this question is answered in my write up, I'd advise reading though it before doing anything else...in my sig
I will add that if you ground the pin to fool the ECU into thinking the transmission is in neutral you will lose cruise. I wired in a switch to toggle this "feature" at will.
