Old 06-20-2007, 05:20 AM
JaySVX's Avatar
JaySVX JaySVX is offline
ECU and TCU pin-outs
Does anyone have, or know where i can get, the pin-out's of the ECU and TCU? Also if you could tell me where they're located in the car as well it would be greatly appriciated. Thank you.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-20-2007, 11:15 AM
JaySVX's Avatar
http://serial.cc/pdfs/ELETRICAL_COMPONENT_LOCATOR.pdf
This has a bunch of electrical boxes and ecu's but is there a main ecu that might be under a different name?
Old 06-20-2007, 11:47 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Put your head down by the brake pedal and look directly upwards under the dash. You will see two boxes next to each other about 6 inches by 4 inches by an inch deep with a zillion wires coming out of them. The one with the yellow plugs is the ECU. The one with the black plugs is the TCU.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
