Old 06-19-2007, 08:26 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Electronic Counter Measures ON
Send a message via ICQ to Sov13t Send a message via AIM to Sov13t Send a message via MSN to Sov13t
Tachometer being interesting?
Already discussed this with OT... but was wondering if this has happened to anyone else... today I noticed that when I go above 3.5-4k RPM my Tachometer begins to jump around... like it doesn't go up smoothly but instead it looks like it sticks to something and jerks up or down... the engine runs normally.
I will be taking it apart this weekend. I also have a spare one... so I am not worried but still we both thought it is fairly weird and uncommon.
-Sov
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 06-19-2007, 08:46 PM
michael's Avatar
michael michael is offline
What Potholes ???
My guess would be the drive gear for the speed sensor is about to fall off its axle. What ever holds it in place is gone or loose and it grabs randomly.
Wanted: Steering Wheel
Old 06-19-2007, 08:55 PM
Sov13t's Avatar
Hmm... would have to check it... One is in the trans axle case, the other is in the torque converter case... which one should I prioritize? However, I think it is easier to remove and install a different cluster since I already have one spare... to make sure its just not the cluster itself...
Any other ideas though?
Old 06-19-2007, 08:56 PM
Trevor's Avatar
Trevor Trevor is offline
Not a good guess as no drive gear or axle involved. The tacho in itself is probably the likely culprit. Hair spring, pointer bearing, obstruction within the movement. Alternatively there could be a faulty connection in the operating circuit.
Trevor, New Zealand.
Old 06-19-2007, 09:06 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Yeah, the tach is controlled by the ECU. If there was an issue there, the car would run funky. I'd bet your problem is in the cluster itself.
Old 06-19-2007, 09:46 PM
Sov13t's Avatar
Great, will check it out and report back.... perhaps will just install a new one and forget about it... planning on installing HIDs this weekend
Old 06-20-2007, 04:51 AM
michael's Avatar
What Potholes ???
My apologies, Trevor and Hocrest are correct. I should have read your post better, I thought you were refering to your speedometer.
Old 06-20-2007, 06:08 AM
Trevor's Avatar
Michael,
It was easy to fall into this trap as the speedometer fault has so often been discussed. Not a problem, particularly as your thoughtful apology enhances the thread, makes the/my day and is sincerely appreciated.
Cheers, Trevor.
