Old 05-27-2007, 01:37 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Pre-Cats
After frying my main cat at Summit Point, I'm thinking it is time to replace the pre-cats also. Magnaflow has a universal fit unit #50004, which says it is suitable as a replacement for the OEM pre-cat and which costs about 1/3 as much. Looking at the diagram on Subaruparts.com, it looks like the O2 sensor mounts just upstream of the pre-cats. Does anyone know whether there might be a problem with pulling out the OEM pre-cat and putting in a replacement? Thanks.
Old 05-27-2007, 04:10 PM
I was planning on doing the same with my system, and replacing the main cat with a Magnaflow cat # 94007. The only problem is that the Magnaflow pre-cats are 2" in and out, and their main cat is 2" in, 2.5" out. I think the pre-cat piping is smaller than 2".
I'm thinking of just cutting the pre-cats off from the rest of the pipe, finding the apropriate adapter, and clamping or welding the magnaflow parts onto the old pipes.
Or you can just buy some flanges and build your own 2" pre-cat pipes.
Old 05-27-2007, 04:35 PM
I think the pre-cat piping is the same size as the inlets to the main cat, which is 2". My muffler guy thought I would need the pre-cats to pass emissions.
Old 05-28-2007, 08:00 AM
It depends on where you measure the piping.
Right after the header flange they are 2.11"
for most of the front pre-cat inlet pipe, it is 1.91"
after the pre-cat its pipe is 1.68"-1.61".
According to Magnaflow the 94007 is legal in 48 states.
Good morning Dan, Pilot.
Old 05-28-2007, 09:16 AM
Tom:
Thanks for the info. If the connections for the Magnaflow 50004 are 2", I'm sure my muffler guy can make the transition. Do you think there will be any problems with the O2 sensor. How have you been? Hope things are going well for you. Saw your website. Wish I were close enough to give you some business.
Old 05-28-2007, 09:37 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
PreCats
The oxygen sensors are mounted just a touch over 4" in front of the precats and the precats are 11.5" long. There should be no problems with sensors or mounting as long as the replacement precat is 14" long or less. You might even fit a 15" replacement.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 05-28-2007, 01:23 PM
Lee:
Thanks for the information.
Dan
Old 05-28-2007, 07:31 PM
Originally Posted by svxfiles
According to Magnaflow the 94007 is legal in 28 states.
I thought it was 49 states (or at least 48)
Old 05-28-2007, 08:09 PM
Yes, 48 states.
I will have to have Di spell check AND read for content!
Old 05-29-2007, 10:15 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I recently had mine done. #50004, # 94007
Old 05-29-2007, 01:09 PM
Quick question: What did you do for a flex point in the exhaust? The stock exhaust has the spring bolt flanges on the main cat. I was thinking of putting in a peice of flexible tubing behind the main cat for mine.
Also, I ordered my 94007 yesterday, but the local guys can't get the 50004's except by special order from Summit Racing, and they're back-ordered to mid June.
Old 05-29-2007, 09:36 PM
dannmarr's Avatar
I work for my SVX
No flange. I had a bracket welded under the Y-section for support. It's not moving anywhere.
Old 05-30-2007, 09:47 AM
those are the same Pre-cats I had on my old exhaust... Then I killed my cats all together
