Old 06-04-2002, 05:10 AM
svx_commuter's Avatar
Question Adjusting Nut Size On The Rack
Anybody with a rack?
Does anyone have the steering rack out? I am looking for the size of the nut, the big hex, that gets loosened to tighten up the steering. A special wrench is need to do this and I think I can make it for less than Subaru wants to charge.
Thanks
John
Old 06-06-2002, 10:03 AM
This is supposed to be a standard part of the 30k maintenance
Old 06-06-2002, 11:03 AM
LarryIII LarryIII is offline
I was once on a rack. It adjusted more than the size of my.........
Larry IIII
Old 06-25-2002, 10:27 AM
Someone has to have a rack somewhere to measure this. Please.
Old 06-25-2002, 06:10 PM
gl1674 gl1674 is offline
What's wrong with using 20' pipe wrench?
Old 06-25-2002, 08:08 PM
Invisible avatar
Cool
Oh.... STEERING racks. Sorry, I thought we somehow got off on the topic of motivational techniques in a Turkish prison.
Never mind.
Ron
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 06-26-2002, 10:28 AM
To get to this lock nut the front stablizer bar has to be dropped. Then you have to reach thru an opening in the subframe with a special wrench to turn the lock nut. It has to be a very thin wrench to do that.
Old 06-26-2002, 06:20 PM
Sorry - I've adjusted mine with the rack out, of the car, so I did not have the clearence problem. You could always disconnect the steering linkage and rotate the rack around it's axis to get a better access to the nut. I am not sure how far it will rotate, especially with tie rods attached, but rotation is a part of standard removal procedure...
Old 06-27-2002, 06:45 AM
Do you happen to remember what size the LOCKNUT was?
I would have to disconnect the hoses to rotate it. Right?
Did you rebuild your rack?
How is your transmission running?
