Old 06-06-2002, 12:52 PM
John Glauser
Rear axle
Need help rear axle binding when turning corners, replaced differential did not help. Does anyone know what i should check next?
Thanks, John
ATVSVX
Old 06-06-2002, 01:54 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
Re: Rear axle
Thanks, John
ATVSVX
Tires? just a guess. Are they all the same size and wear?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 06-06-2002, 04:22 PM
Earthworm's Avatar
Meow!
Try putting in the FWD fuse and see if the problem goes away. I'm assuming you have no tranny codes (flashing power light on startup).
I'm troubleshooting a TCU issue in which binding is one of the symptoms. I was quoted CAD$1000+ for a new TCU when it should only be around CAD$750.
Old 06-06-2002, 05:02 PM
Boone
Jeepers Dave, A new TCU is only 460+ and used go from 150 to 400 US. Some links...
http://www.subaruparts.com/diag/?mod...category=184-A
http://www.car-part.com/
http://www.subaruworld.com/
http://www.ourecms.com/
John, Has your tranny got nice sweet pink oil in it? The symptoms usually indicate a problem with the transfer cluch in the tail section.
