Old 11-20-2006, 07:12 PM
anthonybuchanan anthonybuchanan is offline
Muffler rattle sound
My black 95 has had a muffler rattle since I bought it years ago. Someone told me there is an inexpensive solution for this and the it occurs often.
Anyone know about rather this is common and is it easily fixed.
Old 11-20-2006, 07:33 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
where is the rattle coming from??
There are heat shields all over the exaust, its most likley one of them, just remove it
Cheers,
Jake
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 11-20-2006, 07:38 PM
Holy ****.
I'll check for the heat shields. Thanks.
Old 11-20-2006, 08:46 PM
If it happens only at specific RPM's go after the heat shields. My ford had two screws come loose and the heat shield rattled like a ***** from 1100-1300 RPM. Either remove them, or screw them back into place.
Old 11-20-2006, 11:29 PM
Dessertrunner's Avatar
If it is not the heat shield it will be the centre "Hot Dog" (Oz Name). Just cut it out and put a pice of straight pipe in.
Tony
Old 11-21-2006, 05:21 AM
dcarrb dcarrb is offline
My vote goes to the heat shield. Both of mine rattle when I close the boot (and seemingly ALL of 'em on the silver rattlle at hight idle).
dcb
Old 11-21-2006, 07:36 AM
Speedklix's Avatar
Locker Link Solution
Even if the bolts hang on, the mess that insulates the pipes wears out and eventually you get metal to metal noise.
The only ones I ever leave on are the ones welded to the manifold.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
