Old 07-17-2006, 11:04 AM
Green1995SVX
Originally Posted by immortal_suby
The yellow box in the picture is the driver front ABS sensor
Airbag sensor
Old 07-17-2006, 06:22 PM
immortal_suby's Avatar
Thread Killah
Originally Posted by Green1995SVX
Airbag sensor
of all the brain farts! yes - airbag sensor is what I meant.
Locker Link
2015 BRZ Limited 6MT
Old 07-18-2006, 05:57 AM
seion seion is offline
Subaru Engineer Wanabe
Bad news - it seems the tranny on my new '92 SVX is slipping on 3rd I believe, not responding as well as it ought to. Haven't changed any fluids yet or installed the Perma-cool filter and cooler (hope to receive those soon). Only put in a bottle of LUCAS Tranmission Fix, but just a preventive maintenance. Haven't adjusted the bands, so that is in the menu of things to do. Any advice from you guys is really appreciated; shes is too beautiful to let her die...
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 07-18-2006, 06:20 AM
Thread Killah
The brake band may fix it. The brake band isn't a band aid fix, it is the real deal so try it soon and don't drive on that slipping tranny until you adjust the band.
Locker Link
Old 07-20-2006, 09:22 AM
10-4. Here's a pic of the adjustment bolt and lock nut. By the looks of it, do I have enough bolt travel to make the adjustment? It's the first time doing this, so I don't know if it looks OK. Also, I understand I need to immobilizr the lock nut while turning the adjustment bolt.
BTW, just got my tranny cooler and filter kit - hope it helps.
Old 07-20-2006, 12:18 PM
* * *bump* * *
Old 07-20-2006, 06:32 PM
Thread Killah
If you mean that you only show a couple threads above the locknut - heck, I don't know. I never payed it any attention. I think you will be fine. What hav eyou got to lose?
Just back off the lock nut - 17 mm IIRC. Once that nut is loose use a small 8mm wrench on that square nut. you will not be able to turn it too much at a time and you'll be doing it mostly by feel but it can be done with patience. The first time you do it you'll be hating life but after that it really is pretty easy.
Remember - disconnect the battery first or you will get a nice lightshow when you drop your 17 on the starter bolt.
actually - here's a good how to on the brake band
http://www.subaru-svx.net/forum/show...ght=brake+band
Locker Link
