I like that idea. I use a light bulb to charge/discharge my capacitor any time I have to disconnect the battery.
Here we go again
Ok, so thismorning i drove my car and when i parked it i was hearing a clicking sound from the trunk and my seatbelt was going back very slowly in small steps. I didnt have time to mess with it and when i got back the battery was dead. I had a friend jump me and it was working and when i drove to work it started doing it again so i unplugged the battery. I plugged it back in and it started right up. I got home and it was doing it again so i decided to get your guy's opinons. Anything?
Teal 92 SVX LS L with 103k Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks) |
Well, that sounds like a faulty circuit or relay on the auto seatbelt.
Bring it to an auto electrician and explain what happened. he should be able to sort it fairly quickly. Joe
Battery Dying?
Does anyone know which fuse supplies power to the sun visor's vanity light?
I put a test light between the negative battery terminal and the body to test for a voltage leak. It shows a pulsing light that goes away after a few seconds. I pulled every fuse and relay from both boxes asside from the airbag fuses, with no change. I also tested any aftermarket equipment. Thanks for any help/advise.
