John |
i had a problem on a blazer i had that clicked and wouldnt start so i replaced the battery stater and alternator. still no luck it was a fuel pump. waste of cash and lots of hassle and to top it of the pump was in the tank. i have not heard anything on svxes fuel pumps ever gone bad.
This is a common XT6 problem as they age. The cable looks good on the outside but is corroded about a 1/2 inch in. Replacing the cables works. My XT would click and click on end until it would start finally so that could be it too.
my svx would do the same thing for a day or two awhile back. it turned out to be a bad neg. battery cable. while it looked to be in ok condition and the terminals showed no corrosion, the cable was bad about half way in the middle of it. found this out while shaking everything i could touch while someone else continuousely tried to crank it.
Can the mods please merge these 2 threads?
Oops...didn't realise that until now. Thanks for being on the ball!
Ok guys well im gonna try that stuff starting with the cheapest things 1st.. and work my way up.. i need to get it running though, thanks for the help.. anybody esle have any suggestions??
