Old 05-11-2005, 12:31 PM
north of the 49
O2 sensors and the EGR
2 quick questions.
1- I have read on here people have cut out their front cats alnong with the front o2 sensors? How can this be done without setting of CEL?
2- My car keeps throwing a #43, which could be the EGR circuit, value and /or seliond. Could this also cause ruff idle and poor performance? the reason I ask is the car worked so well for about a month with this problem, then it really went down hill, no power, ruff idle etc.
Its a 94 svx and without this forum I don't think I would of bought it. thanks for sharing.
Old 05-11-2005, 12:34 PM
immortal_suby's Avatar
Thread Killah
The 02 sensors are in the pipe in front of the front cats, not in them. I don't think anyone has removed the 02 sensors.
Locker Link
2015 BRZ Limited 6MT
Old 05-11-2005, 01:56 PM
north of the 49
Right, but I thought I saw a post where someone removed them and just used the third cat and sensor. Also would a bad EGR cause a cherry cat?
Old 05-11-2005, 02:28 PM
deruvian
Only the 96 and 97 MY have the third O2 sensor.
Old 05-11-2005, 03:17 PM
Earthworm's Avatar
Meow!
Welcome to the site. Where in Canada are you?
You mentioned error code 43. I think you mean 34 correct?
Old 05-11-2005, 03:26 PM
north of the 49
Thanks. i am in Edmonton. As far as I could tell is was a 43. Tried it three times, #43
Old 05-11-2005, 03:32 PM
How do you read a code?
Old 05-11-2005, 03:33 PM
north of the 49
On second thought you were right #34. Damn Dyslexia!
Old 05-11-2005, 03:34 PM
Thread Killah
Look in the how-to documents under the engine\codes folder.
Locker Link
Old 05-11-2005, 04:47 PM
Earthworm's Avatar
Meow!
All the different codes are also on http://svx-iw.com/ in the codes section.
Old 05-11-2005, 06:24 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
mine did threw the same code after i started driving it again. i replaced the egr valve and it threw the code again and continued to run badly at idle. i noticed, however, that it would only throw this code after it stalled. i changed my o2 sensors and the problem went away entirely.
hope that helps some.
Old 05-11-2005, 09:57 PM
north of the 49
thanks for the advice. I hope it works out cause from the first time I drove it I was hooked. Dam what a fun car to drive.
Old 05-12-2005, 06:54 PM
OMG i had no idea that u could do that . now i have to print them. Thanks
