Old 05-05-2005, 07:05 AM
Sybaris Sybaris is offline
Mystery Part
In the process of changing out my PCV valve (can't get the d@mn thing off) I found this laying on top of the engine below and behind the valve. What is it?
1997 Bordeaux Pearl LSi ~45K
Old 05-05-2005, 08:00 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Man, I have no idea. I've not seen anything like that. Perhaps it was a part from another car that a tech dropped while working on the SVX in its previous life. Anyone else have a clue?
Randy Johnson
Mike Davis -- at Reading VI
Old 05-05-2005, 08:16 AM
THAWA
It covers the access port on EJ/EG/EZ engines.
Old 05-05-2005, 08:29 AM
Thanks! Where exactly is the access port?
Old 05-05-2005, 09:22 AM
dcarrb dcarrb is offline
Atop the bell housing; it allows access to the flywheel. It's upside-down in the first photo. The ridges shown force-fit inside the opening.
dcb
Old 05-05-2005, 12:04 PM
KCROGUEDOG
a bicycle seat
Old 05-05-2005, 12:10 PM
Earthworm's Avatar
Meow!
What usually happens is that the little tabs that hold that piece in place break off over time and the piece falls off.
You will find where it goes if you look at the top-back of the engine on the passenger side. Through the hole you will see the gear of the torque converter. Your best bet is to put a bead of silicone on it before putting it back then allow it to sit overnight.
Old 05-05-2005, 12:43 PM
Thanks.
Isn't it kinda odd where I found it? Seems like it woulda fallen on through the engine compartment.
Old 05-05-2005, 02:54 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
HA! that's what that was? i found one of those when i took out my engine awhile back... i think i might have kept it "just in case"
Old 05-05-2005, 03:52 PM
Earthworm's Avatar
Meow!
I found mine there as well. I eventually bought a new one. That's how I found out the tabs were broken off my old one.
Old 05-05-2005, 09:56 PM
THAWA
Well it's actually only to allow access to the flexplate/torque converter. You shouldn't be doing anything to the flywheel through the access port.
Old 05-05-2005, 11:11 PM
Unless you are pulling the engine.
Old 05-06-2005, 12:22 AM
THAWA
Why do you need to get into the accessport on a manual if you are pulling the engine?
Old 05-08-2005, 12:09 AM
ThetaReactor
So there's a cover on the top of the tranny and a gaping hole on the bottom. Figures...
Old 05-08-2005, 08:47 PM
THAWA
The port it on the engine. What figures?
