Old 04-29-2005, 11:26 PM
914helo 914helo is offline
Camshaft sprocket wrench
The manual says to use tool # 499207100 to keep the camshaft from turning when I try and loosen the bolt. I can't find a picture anywhere and Subaruparts.com has the item discontinued. Does anybody have a picture of one? Is it really needed? I was going to rig something up but if you guys think I might damage something I'll try and buy one. Hey, I'm always up for buying more tools Either way I need to figure out a way to remove the camshaft sprocket. Thanks
Kent
Old 04-30-2005, 06:49 AM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
if you have an impact gun you would not have to use the tool... why are you removing the sprocket?
Old 04-30-2005, 07:02 AM
immortal_suby's Avatar
Thread Killah
I made this for mine
Locker Link
2015 BRZ Limited 6MT
Old 04-30-2005, 07:03 AM
Thread Killah
You will still need something to hold the cams in place to torque the bolt tight when you are done.
Locker Link
Old 04-30-2005, 11:13 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Generally, it's the easiest way to replace the cam seals.
Old 04-30-2005, 12:12 PM
I was planning on replacing the cam seals and put in a new water pump while I'm down there. Thanks for the pic immortal. Maybe I'll try and put something together today.
Kent
