Old 08-14-2004, 07:41 PM
Paul
Talking SVX goes faster in manual mode?
It seems that I get better acceleration through all 4 gears when I run in manual mode. I actually seem to be getting used to shifting instead of keeping it in drive.
Is it OK to use the SVX Tranny like this? It sure does seem faster!
Old 08-14-2004, 07:44 PM
tancred
It would seem faster in my old SVX aswell, but i toasted the tranny being a shifta-holic now shifting is reserved for BMW M3's and the likes...
Old 08-14-2004, 08:06 PM
Darth Bagel
the hell does manual mode do? i never had the courage to try it, and i never remember to check the manual.
Old 08-14-2004, 08:37 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
manual mode is for use in conditions where there is little traction. It starts out in 2nd gear and holds the gear longer to reduce wheelspin. I don't see how this would help acceleration.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 08-15-2004, 01:55 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
I take it that you mean starting in 1st gear and moving the stick through 2nd, 3rd & D?
This will give the feel of better acceleration, but without timing, it is hard to confirm this.
New Subies have a gated stick, which discourages this sort of use. Could it indicate that manual changing puts extra strain on the tranny?
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 08-15-2004, 02:48 AM
Rotorflyr's Avatar
Rotorflyr Rotorflyr is offline
Actually Andy,
Depending on which model of "new" subbie your refering to, some actually encourage this by way of the 5EAT Sportshift....
Old 08-15-2004, 02:54 AM
Andy's Avatar
Originally posted by Rotorflyr
Actually Andy,
The sportshift is a completely different animal. The SVX has the 4EAT, and the newer derivatives use a gate. I believe that the 5EAT was designed with the shift buttons in mind.
Andy
Old 08-15-2004, 03:12 AM
Rotorflyr's Avatar
I do of course realize that 5EAT is a different animal , although Im not sure if it was designed with the shift buttons or not as it also has the "shift gate", but it would be interesting to see how well one works in an SVX
Old 08-15-2004, 11:44 AM
the 5eat is a dream. i've only experienced about 100 miles of driving it though.
Old 08-15-2004, 08:01 PM
BoondockSVX
Would a 5eat bolt into an SVX?
Just wondering.
Old 08-15-2004, 08:20 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
It probably would fit, but you'd need to modify your driveshaft, as the 5EAT is slightly longer...
Also, you'd need to get a matching TCU as the SVX's wouldn't be compatible.
-Chike
Just wondering.
2006 Steel Gray WRX TR (sold)
Old 08-16-2004, 10:10 AM
Earthworm's Avatar
Meow!
From my understanding Manual mode is ignored unless the shifter is in 2 or 3. In 2 the car starts from a dead stop in 2nd gear. In 3 the car still starts in 2 but will shift to 3 as soon as possible.
This would slow you down if anything.
Old 08-16-2004, 10:46 AM
red95svx
Some members (such as myself), like putting the tranny in manual mode and shifting through the gears ourselves. I realize that you don't NEED to put the tranny in manual mode in order to do this, but it is a lot less likely to downshift and upshift on its own if you do. Subaru also says that putting the tranny in manual mode forces it to use a "more agressive AWD map", possibly giving the car a different feeling due to changes in torque distribution. Does it make the car faster? Probably not, but it is fun!!
Old 08-16-2004, 05:53 PM
oab_au oab_au is offline
Hi Dave, yes when it is in Manual Mode, the TCU applies the transfer clutch, much earlier than normal and with more pressure. This is because, this Mode is for use in slippery conditions, so the slight binding that will occur, will not be a problem on the slippery surface.
One Arm Bloke.
Tell it like it is!
