Old 06-13-2004, 06:51 PM
poweredx2 poweredx2 is offline
air fuel ratio gauge
This is an old question that didn't get a answer,why would a a/f ratio gauge go blank using a 100 shot of nos an not a 50 or 75 shot or even on motor it don't go blank.I talked to a few mechanics said that maybe the zex kit bumps up the fuel pressure so high that it will not register,sounds like a possible answer.The car pulls like a train even after the gauge goes blank,comeon guys I am puzzled about this one.
Old 06-14-2004, 08:48 AM
mbtoloczko's Avatar
sans SVX
When you say "blank", so you mean the indicator is pegged at either full rich or full lean?
Mychailo
Visit my locker
Old 06-14-2004, 10:54 AM
AFBeefcake's Avatar
Subaru Swapper
No, he means the there are no LEDs lit up on the gauge. Mine does the same thing, but I don't have NOS.
2005 Legacy GT
My WRX's Cardomain Page
Old 06-14-2004, 11:39 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
if no LEDs are lit up, that means you're "off the scale" rich or lean. I'm guessing with a 100-shot you're off the scale on the rich end.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 06-14-2004, 12:00 PM
mbtoloczko's Avatar
sans SVX
I'm wondering, is it even possible for the signal to go "off scale"? I had thought that narrowband O2 sensors produced a signal between 0 and 1 volt, and narrow band O2 sensor gauges just show that voltage.
Mychailo
Visit my locker
Old 06-14-2004, 12:11 PM
IggDawg's Avatar
0h n0es!
I'm not sure how they work exactly, but I know I've seen it go so far to rich or lean that the last LED is so dim it's barely visible. I can imagine in extreme conditions that the sensor could behave strangely. any idea if it "pegs out" at one volt and holds that signal, or if it just stops signaling altogether?
IggDawg is cool
-IggDawg
Old 06-14-2004, 12:14 PM
AFBeefcake's Avatar
Subaru Swapper
If I had a O scope I could see if there was a signal, but I don't have one. sorry
2005 Legacy GT
Old 06-14-2004, 08:31 PM
A/F
What kind of A/F gauge do you have? My Nordskog digital A/F cycles, from blank, up to 2 amber bars into the rich side. A picture is worth a thousand words.
zipped video file of a/f gauge
OK, that took 41 days. But onto the (potential)problem, As I understand it, nitrous oxide has 2 oxygen molecules, for every 1 oxygen molecule, What that does is provide more oxygen into the mix, if this is an AIR/FUEL mixture, then the mix is leaner! So with a 100 hp shot, the mix is leaner than with a 50 or 75 hp shot. Unless you are suppling more fuel, the engine will run lean. Tom.
Old 06-15-2004, 07:43 AM
a/f gauge
The zex kit bumps fuel pressure by applying vacuum to the fpr or taking away vacuum but it sure works.Also I think its pegged full rich because the plugs are indicating a good mixture,but I'm in the process of hooking up my other stage again without the nos just the fuel.It will work like this I will up my zex to a 125 shot and it will provide as much as it can but for added safety I'll have fuel fogger no nos jetted with a 20 shot ,the parts are cheap and I think it'll be pretty safe and rich,give me some feedback.Oh I have a autometer a/f gauge.
Old 06-15-2004, 08:19 AM
Fuel pressure
Do you have a fuel pressure gauge? Stock is 36.3, but the pump is capable of much higher. The math formula to find the new flow/output is as follows. Take the new line pressure, say 45psi, and devide it by the original 36.3psi, and you get 1.2396694. Now get the square route of that, (thank God for that calculator function) 1.1134044, and multiply it by the factory rated flow of 275cc/minute and you now have 306.18621cc/minute injectors.
Old 06-15-2004, 09:40 AM
a/f gauge
I am ordering a legacy fuel pressure regulator it has more pressure and I will see can a fuel filter from a 95 civic si work on our cars only because it has a port for an aftermarket pressure gauge to keep an eye on the fuel pump,it won't be the only honda part on my car I already have 95 accord sunvisors with extendions.
