Old 03-11-2004, 05:11 PM
lee lee is offline
Cam & Crank seals
Went to my new local dealer and they did not have the parts in stock (I'm not surprised). But my local Car-Quest parts place did have Beck/Arnley brand cam & crank seals and timing belt in stock.
I double checked the B/A part numbers on the web, and the part numbers check out for the SVX.
So, anybody know if there is a reason I shouldn't start taking my car apart?
I ask because I got burned using the BCA catalog part numbers for the rear wheel bearing seals - turned out they have/had the wrong numbers in their catalog. O/T to my own post, but I always wondered if they listed the seals for a FWD model and the data entry person figured it would be the same for AWD.
Old 03-11-2004, 09:23 PM
Bobb Bobb is offline
Parts
Hi Lee, I don't know what the mileage is on your SVX , but I would like to get at least as many miles out of the replacement parts. So, unless you got poor life out of the OEM part, I would get on the horn or keyboard to some place like Subaruparts or Liberty Subaru. Take care, BOBB
P/S You don't where those other parts have been! "B"
Old 03-12-2004, 05:06 PM
lee lee is offline
Thanks Bobb,
However, I went ahead and bought the Beck/Arnley parts and did the swap. Time will tell.
Old 03-15-2004, 10:35 AM
MikeInd
Cam & Crank seals
You could get the complete seal kit for the car.
# 10105AA060 Engine Seal Kit $ 253.62
Yes, It might seal expensive....but it is OEM and it is ALL the seals that you will ever need....so down the road....you can fix what leaks...
my thoughts
Old 03-16-2004, 07:30 PM
Mr. Pockets's Avatar
Moderator
I'm a little surprised to learn that there are aftermarket timing belts. I thought those were dealer-only.
I wonder if the popularity of the WRX has attracted some a/m manufacturers to make Subaru stuff.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-16-2004, 07:56 PM
lee lee is offline
Don't know, but the seals/belt came packaged stating "made in Japan". The belt had the Mitsubishi name along with numbers (but no symbol like the cars).
I assume that Subaru (I know Toyota does this) has captive parts sources. Toyota holds them to 10 years before allowing them to sell items in other distribution channels. 2004-1992=12, so...
Too bad I don't still have the packaging for the seals, I'd report any other markings and see if anybody recognizes numbers, or ???
