Old 03-03-2004, 07:24 PM
lee lee is offline
Originally posted by civic_slayer
thanks for the responses guys. The only reason i asked is that most say that a little, and i mean LITTLE, diesel fuel actually helps clean out the cars innerworkings. May just be a myth. Thanks anyways.
Myth.
Diesel in gasoline: It's a less refined fuel with more soot, etc. Not likely to clean. More likely is it would clog fuel injectors. If you have the cash, just buy a can of Techron. A pint of toluene with a full tank every couple of months gets the job done cheaper - get a year + supply (gallon) of it at Ace Hardware for like $15.
Diesel in oil: It would wash down the cylinder walls by diluting the oil - accelerating cylinder wall & piston ring wear - not a good idea. Buy something like Auto-Rx (http://www.auto-rx.com)
Diesel in transmission: (Shuddering thoughts) again try Auto-Rx (http://www.auto-rx.net)
BTW, I work for Uncle Sam, not Auto-Rx...I've just seen many testimonials at the oil forum - probably time to list this site again - cruise it for fuel/oil/ATF questions and other product info. (http://theoildrop.server101.com/cgi/ultimatebb.cgi)
Old 03-03-2004, 11:41 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
Re: 110 leaded
just a little Q. In idaho you can get 110 octane trick racing fuel from the pumps. I read that the minimum an SVX should use in 91 octane. Is it kosher to run one gallon of trick in a full tank of 91 or 93 octane?
I did just a squirt some time ago, not more than .082 of a gallon. and it didn't seem to hurt the car. There wasn't that much race fuel in the tank but it seemed like it actually did help somewhat.
let me know if it is cool to mix 91 and trick race gas.
The fuel you are referring to I am assuming is at the Stinker station on Overland here in Boise. To be quite honest, here is the ups and downs.
First off this is a leaded fuel. It will destroy your catalytic converters (all three) as well as cause premature failure of your O2 sensors.
Next, yes you will see a performance gain by running a higher-octane fuel. But let me add that this difference is only seen in the numbers and really is not a perceivable “feel.” I made test passes at the track with years of time slips to compare to running on different fuels. The code in the SVX computer that control ignition timing is adaptive (to a point) and will occasionally advance the timing under the right circumstances to “test” the fuel. It will slowly advance it until it hears fuel knock and then cut it back until it stops. If ant any time if hears knock again, it will reset its timer/counter and knock the timing back again until fuel knock is gone. To see or make changes faster, put in higher-octane fuel, drive for a bit to get it cycled into the fuel rails, then stop the car and disconnect the battery for a while. When you re-connect it, drive it like you stole it in order to get the maximum effect from both the ECU and the TCU. They adapt to your driving patterns. Again, keep in mind the difference in the ¼ mile or light-to-light will be nearly unperceivable. Top speed and wide-open throttle will show substantial improvements. Keep in mind factors of altitude, and air density. Someone at sea-level will get a greater gain than someone in Denver.
If you really want to play with this idea with safe operation, use VP Performance Unleaded (R+M/2: =101 octane) or VP Motorsport 103 (R+M/2: =103 octane). Both are unleaded, wont harm emissions systems or O2 sensors, and they both are street legal.
There is so much more I need to put in here, but my time is limited now. Will add more soon.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 03-04-2004, 08:25 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
thanks for the earfull Chris. just wanted to put some myth and fact together. I don't plan on ever running and higher octane fuel ever again, even though i did it once. so Chris, how about that coffee. i do live in caldwell
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 03-06-2004, 04:08 PM
MYgreen92
well, im not sure how an n/a car reacts to higher octane fuel, but a friend of mine actually gained 21rwhp on the dyno by switching from 93 to 116 octane fuel in his 94 Supra TT (with only basic mods, intake exhaust, apexi safc, etc), and i ran a full .2 sec and 2 mph quicker in my 89 supe turbo by running 116 (note, 60' times were exactly the same both runs, which were 3 minutes apart)
