Taking Apart Door to Get to Window
My window was shot out with a BB and I had it replaced today. problem is, they didn't clean out all the broken glass out of the door. The new window is now stuck inside the door and won't come up. Is it hard to take the door off? Could someone give me some instructions on how to do it? Thanks a lot.
you can probably find more detail if you search for sleeve lock regulator (which is a different problem, but still requires door panel removal). Here's the basics:
Need a Phillips screwdriver, medium sized, and a small/thin flat-bladed screwdriver remove two or three screws (I have two, some people have said they have three) under the felt pad at the door pull. remove two screws at the front of the door remove one screw under a plastic trim piece, which is under the inside door handle. get that plastic trim out with the small thin flat-blade. then pull on the bottom of the door panel to release the snap clips, lift door and slide it off. careful of the wiring - two harnesses to release I think, one for the window switch, one for the light |
Thanks so much!
In case you didn't find it.
Also a note. Be careful witht he wires going to your window switches. It's kinda short.
http://www.subaru-svx.net/forum/show...&threadid=5403 Randy ii |
What a crappy glass company Hope you get it fixed rite.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
