Old 07-27-2001, 10:42 AM
KEVINL
ngk Part number
Does any body know what the part number for NGK spark plugs for the SVX
Old 07-27-2001, 11:50 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: ngk Part number
22401AA370
Randy Johnson
Mike Davis -- at Reading VI
Old 07-27-2001, 12:13 PM
KEVINL
I should have clarified I need non platnium NGK R plugs one heat range colder than stock
Old 07-27-2001, 12:53 PM
Aredubjay's Avatar
Oops. Sorry. Then, you'll have to talk to someone else.
Randy Johnson
Old 07-27-2001, 05:24 PM
Red SVX 92 Red SVX 92 is offline
Hitchhikin'
I have those plugs, Kevin. I'll check the numbers and post them by tonight.
Old 07-27-2001, 05:45 PM
Hitchhikin'
Damn, I don't see any number even close to what Aredub posted earlier on the box, and I don't have my invoice with me right now. This is the only info I have:
PFR6B-11 <---- Old platinum stock spark plug
BKR7E-11 <---- New non-platinum plug, one heat range colder
^^ PF = Platinum
^ 7 is one heat range colder than 6.
That's what I remember, from what my tech told me.
And if I had to guess at what you were up to, I'd say nitrous.... I don't remember turbos needing non-platinums.
Whatever it's for, good luck. If you need more info, I'll see what I can find.
Old 07-27-2001, 06:11 PM
Aredubjay's Avatar
The number I gave is the Subaru part number.
Randy Johnson
Old 07-28-2001, 12:00 AM
KEVINL
Thanks thats cool the SVX uses the same spark Plugs as my dads 99' RS-T
Old 08-03-2001, 10:30 AM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
This account is scheduled to be deleted for inactivity
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
^^ PF = Platinum
Actually most tech will tell you NEVER to use platinum plugs in a turbo car. I gues they get too hot or something. Makes the car more prone to detonation.
This is probably why my friend screwed his Merkur up so bad. Or maybe it was the fact we upped the boost from 8lbs for 14.5lbs. One of the two.
Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
