Old 02-16-2013, 09:04 PM
redlightningsvx's Avatar
Collision Refinishing Tech
No start problem OUTBACK
Just got a 1999 limited 30th anni. outback and it won't start. Put a new battery in it and as soon as I turn to start it the clock goes dim and nothing happens. I jumped the starter from the battery and all it does is crank but wont attempt to start. Main concern is why wont the key kick the starter on, I hear the solenoid clicking when I turn it but it just won't go. I'm getting fuel and spark. Any ideas?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-16-2013, 10:16 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: No start problem OUTBACK
Have you checked the Alternator?
1995 POLO LSI 76K MILES SOLD
Old 02-16-2013, 10:50 PM
NEW alternator
Seth
Past subies:
Other toys:
Old 02-16-2013, 11:48 PM
SVX92-97's Avatar
You obviously have power to the solenoid. Hook the clamp end of your test light to an engine ground then touch the test light to the starter post with the switch in start position. If you get no response to your test light the solenoid contacts are bad. If you get the test light to light you have problems with the starter.
Old 02-17-2013, 07:10 AM
The starters good also. Im just not getting any power to the little connector that goes on the starter.
Seth
Past subies:
Other toys:
Old 02-17-2013, 07:40 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Auto? Check the connector to the shift indicator, it can be together enough to seem to work, but not enough to pass enough current to the starter.
Manual? Check the clutch switch.
Old 02-17-2013, 07:53 AM
Its an auto with the keyless entry/security system. I did pull the fuse for the security incase it had something to do with it and I dont have the remote.
Seth
Past subies:
Other toys:
Old 02-17-2013, 04:07 PM
Figured it out My buddy bought a manual for me and we went over the diagrams and traced the problem to the wire after the ignition plug. There's a short somewhere in it going to the inhibiter switch so i'm running a new wire from the ignition to the switch. After that it started to crank over.
Seth
Past subies:
Other toys:
