Old 09-13-2010, 01:32 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Crank Angle Sensor 2 location pleaase?
I have the following codes:
code 22 (knock sensor or circuit right side )
code 29 (Crank Angle Sensor 2)
code 37 (oxygen sensor No.2)
I need location and part number if any one has them?
on the knock sensor what does the circuit part mean?
Also, can one of these sensors trigger the others? Should I replace them in a particular order and check to see if other codes go away or are they not related at all?
Thank you
Old 09-13-2010, 02:10 PM
Re: Crank Angle Sensor 2 location pleaase?
Actually I only need location and how to replace for the Crank Angle sensor 2.
Old 09-13-2010, 04:51 PM
See, they phrased the sensors funny when they did the descriptions... Right not I want to say Crank angle sensor 2 is secondary sensor on the oil pump... But I also have a feeling it is what they refer to as the cam angle sensor as well... Either way it is the same part # for the sensor.
Old 09-13-2010, 05:29 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
According to the service manual, its the one under the alternator, right hand side when looking from the front of the car. Remove the alternator, unplug crank sensor harness, and remove 10mm bolt that holds it down. Inspect for lots of crap on the tip..... clean and replace if needed.
Old 09-15-2010, 07:50 AM
thank you for the response. Where can I find a part number?
Old 09-15-2010, 07:56 AM
Re: Crank Angle Sensor 2, price?
anyone have any idea how much I should expect to pay for crank angle sensor #2?
Old 09-15-2010, 08:05 AM
Crank Angle Sensor = Crankshaft position sensor???
Is the Crankshaft Position Sensor(shown in diagram) the same as the crank angle sensor#2
Old 09-15-2010, 09:05 AM
Cam Cam is offline
It should be. The location is correct but the sensor looks slightly different. Where is that diagram from? I have never seen it.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 09-15-2010, 09:34 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Crank Angle Sensor = Crankshaft position sensor???
I have to say, I really like this picture.
[/offtopic]
-Jason
-Obi Wan Kenobi
Old 09-15-2010, 01:38 PM
Cam Cam is offline
i forgot to mention, there is a crank sensor missing in this picture. The oil pump houses two sensors. I can post pictures later if you would like. Right now mine are very visible and may help you locate them.
Cam
'92 Ls-L Dark Teal
Old 09-17-2010, 08:23 AM
Please post the pictures you have. I need to find out which one is crank angle sensor #2. Thank you
The diagram I posted is from Autozone
Old 09-17-2010, 08:53 AM
Here ya go...
Old 09-17-2010, 09:13 AM
Thank you for the pictures. They help alot. The code i got pointed to crank angle sensor2. Why is it called #2 if there's only one crank angle sensor?
Old 09-17-2010, 09:15 AM
Both of those sensors work as crank sensors on the SVX. Just one of them is the same type of sensor as the cam sensor. Each crank sensor serves its own specific purpose reading its own signal relaying it back to the ECU.
Old 01-22-2011, 05:02 PM
oab_au oab_au is offline
Looking at the front of the engine, there are two sensors above the crank pulley. The one on the left is No.1 crank sensor, it has the right angle bend in it. The one directly above the pulley is crank sensor No.2. This has a 45* angle bend, and is the same part number as the Cam sensor that is on the right side of the engine between the battery.
The No.1 is a SVX part only. The No.2. Crank sensor, and the cam sensor are the same as the Legacy/Impressa part.
One Arm Bloke.
Tell it like it is!
