Old 03-07-2018, 09:38 AM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: Small Car Headlight Kit
Ahhhh, ok, I see where we got off track.
My retrofit will be into the glass-lenses of the German headlamps.
Originally Posted by Huskymaniac View Post
My stock lens is full of internal micro-cracks and hazes like crazy. I hear you about the small car lens but at least that is easily replaceable. And, on a related note, when I replace it, I am going to consider adding lenticular film to the inside of the replacement lens. Such things exist and are easy to apply. I suppose I could do that right out of the gate but the headlights I purchased already had the lens put on the old assembly and so I am looking for a solution that doesn't require replacing the lens too.
Old 03-07-2018, 08:05 PM
92 SVX 92 SVX is offline
Originally Posted by SoobCrazy View Post
The lens in the small car kit is not going to stand up to the elements long term, another knock against it. If I were going to do it properly, I'd open the lamp assembly, retrofit whatever lamps I wanted into the housing.
THEN I would polish the Fresnel out of the inside of the OEM lens and stick it all back together.
That is exactly what I thought too, I did this years ago,
But it wasn't without its price.
Old 05-23-2018, 05:58 AM
Huskymaniac's Avatar
Uses the ignore feature
Update
I gave up on the headlights I bought with the small car lenses due to just too many issues with seized screws and bent adjustment thingies. I got a pair of stock lenses from a junkyard car that were in decent shape and just a little hazy. I polished them to get the haze out and clear coated them. I screwed up the clear coat so I sanded them down again and tried again. Screwed it up again. I suck at painting. I put some extra coats with the thought that, maybe I could just buff out the bumps and snakeskin imperfections. It took a long time but I finally got them looking decent and I am pretty sure I didn't go through the entire clear coat layer. I finished them off with the best HIR bulbs I could find. Now I am trying to get the aim right. I think I am close.
Tony
Old 05-23-2018, 06:46 AM
SVX_MY_BABY's Avatar
Update
After I did mine I went to an alignment shop I use. The lift they have is perfectly level. Between jobs they let me drive onto the lift and adjust the levels on the lights to dead centre. Worked great & only took about 5 min. total.
Peter
Display Modes
