Old 12-26-2016, 03:43 PM
ddmd ddmd is offline
1997 SVX Front CAT pipe equivalent?
Hi All. I went to replace the left front CAT pipe (44107PA330) in my '97 and, to my dismay, it's no longer available. Interestingly the same pipe is available is for a '96 (44107PA250) and a '92 (44107PA050). I didn't check '93-'95. I had previously assumed (apparently incorrectly) that the exhaust parts for all of the years were interchangeable. I do remember reading that California and Canada had different part numbers (different CATs?). Aside from a used part, can I use the part from a different year? Thanks in advance for the advice.
Carpe Diem
1994 LSi Laguna Blue 93K
1996 LSi Ebony Pearl 84K
1997 LSi Polo Green 56K
1997 LSi Polo Green 17K
1992 Liquid Silver 206K (parts)
2009 Legacy GT Spec B 46K
2000 Volvo XC70 201K
Old 12-27-2016, 10:23 AM
SVX_MY_BABY's Avatar
Re: 1997 SVX Front CAT pipe equivalent?
The only difference I recall is that the 97s have three O2 sensors while the other years have only two. I don't see how that could affect the actual pipe with precat.
Peter
Old 12-27-2016, 11:11 AM
Dennis,
The 96 and the 97 pipes should be interchangeable. They are both OBDII systems (with the addition of the third 02 sensor at the main cat) which basically does nothing more than keep an eye on the other 2 sensors.
Should not affect what you are trying to do.
Old 12-27-2016, 01:29 PM
Hey John, I assume you meant that the '96 and '97 front CAT pipes should be interchangeable. Interestingly, the Right front CAT pipe on a '96 (44107PA240) and a '97 (44107PA320) also are different part numbers. Is the Catalytic converter itself different?
Where are you guys saying that a '97 has an additional sensor? Behind the main Catalytic converter or before one of the two front CATs?
Carpe Diem
Old 12-27-2016, 05:15 PM
On the OEM rear cats for 1996-1997 (OBDI), the third O2 sensor is located on the top of the cat towards the rear. On the aftermarket ones they were still located in the top of the cat but towards the front.
1992-1995 OBDI main cat. Magnaflow 94007
1996-1997 OBDII main cat. Magnaflow 94037
Old 12-27-2016, 05:23 PM
But to make it easier to service, I just used the OBDI main cat and welded the 3rd O2 sensor bung into the rear pipe, just behind the cat. Gets a much cleaner reading and easier to replace if needed, rather than dropping the exhaust.
Old 01-19-2017, 04:39 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Do you happen to have a pic or two of the rest of your exhaust system? The one pic you posted shows a real, clean and simple system.
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
