Old 08-09-2009, 04:58 PM
Re: 11:1 CR Race/Street Engine build
Update!
Cams from Web are IN!
740cc injectors are on their way
Meziere water pump and fitting are on their way
Silicone hoses will be ordered Monday
1 5/8" Tubing for the headers is on its way, thermal coating after completion
Hydra will be ordered Monday
More to come!
Old 08-30-2009, 11:31 AM
Well, got a good deal of parts here but without have the heads done, I have been spinning my wheels.
RallyBob had not been able to get to the heads before so I have ported and polished them myself. I had been to Bob's shop and he gave me a tutorial on how he ports the heads in regard to the dogleg exhaust port. WIth that knowledge in mind, I was able to port and polish them in about 14hrs. I am happy with the outcome and need to thank Bob for showing me the tricks of the EG33 heads.
That being said, the heads will be off to the machine shop this week and should be assembled this upcomming weekend if I can find the time. Once the valves and all other components are loaded I can then select the shims I will need and order them accordingly. Long block is finally coming together.
I have also prepped a good deal of parts that will be sent off to powder.
In the process I have decided to cut up a water pass-over pipe. The passage through is MUCH smaller than I ever imagined. I will be fabricating a roof ontop of the X-over to increase the X-section and allow for more water to pass through with less restriction. This along with the other modifications to the cooling system should be a good start at tackling the overheating issues with the EG33 when spun to higher than stock RPMS.
More to come, sorry I am not a picture taker, not until the tires are spinning
Old 08-30-2009, 03:28 PM
You should be a picture taker because.... This th....... cs!
Old 08-30-2009, 03:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
YT,
Got your voicemail! Told you that cross over wasn't flowing much
I'll have to have you check out the heads I ported/polished when you come down for the rims/tires.
-Bill (Vicodin is your friend!)
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-11-2009, 08:12 PM
Just when I thought I was done with the Die Grinder... I remember I have to clearance the bucket sleeves... Damn these lobes are huge!!
Old 09-12-2009, 10:34 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Check BOTH sides of the bucket and the sides of the head, and just for laughs check the clearance to the underside of the valve cover with some clay. Remember when everything gets hot, dimensions grow...
Bob Légère
EG33 Impreza tweaks
Old 09-12-2009, 12:34 PM
Yea I am making sure there is plenty of clearance. Remember these cams are slightly smaller than the ones in the EG33RS so I will not need to go too nuts
Old 09-12-2009, 03:57 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Pics! pics!
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-12-2009, 04:07 PM
Get into your Corolla of death and drive down to the shop and take a look for yourself
Old 09-12-2009, 06:30 PM
Get into your Corolla of death and drive down to the shop and take a look for yourself... and bring a camera with you.
Fixed! .....
Old 09-13-2009, 01:38 PM
OK got the RH head lash measurements done. Problem is, the shims I originally wanted to order (2.5 shims) do not come in small enough thickness (less than 2.0mm). Does anyone know where I can find some 26mm wide shims??
Old 09-13-2009, 01:59 PM
Contact THESE guys, maybe they have your application...
Old 09-13-2009, 05:27 PM
SVXelerator SVXelerator is offline
Frequent User
I know a guy who knows a guy...but you've probably already called him
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 09-13-2009, 07:29 PM
Sent them an Email with the specs of what I will need. Lets see what they have to say
SVXRide? Already called him and he said he would check with his guy and see if he would be able/willing to make them
Old 09-13-2009, 07:54 PM
SVXRide's Avatar
YT,
Did a little checking. Can you confirm that you'll want shims that have a Rockwell harness of 45 or greater?
-Bill
