Gremlins banging engine with wrench !
Yesterday from under the hood my baby started making some pretty loud noises. It kinda sounded like someone banging the engine with a wrench. Its wierd, sometimes it happens and sometimes not. I checked the oil, it was down a half quart, I filled it up, no big deal.
Does this sound like the noise that I have heard about with the power steering pump? I think something may be going, but not sure what The noise seemed like it was coming from the alternator or Ac unit or below. I think, sometimes it may be turning and sometimes not. (whatever IT is?) When the rattle/banging isn't happening it sounds like a belt is slipping. The pully below the AC unit should be turning? Right? Thanks for any feedback/suggestions. Tapper |
Could be your flex plate.
I replaced the flex plate about 10 months ago, along with the water pump and timing belt. It actually sounds a bit similar but the source is alot higher and closer to the front of the car.
I am going to search in the lockers of other members to see if anyone has a diagram of 'what is what' in front of the engine. Not being a mechanic(I like to think I know the basics), it is somewhat challanging to figure out every component the belt turns. (I think this may be relavant) I'm lucky I just got another SVX, because now I am driving it. Tapper |
Well, Problem identified.
It was the belt tension wheel (is this what it is called?), below the AC compressor. Half of the ball bearings have disintegrated. It was really LOUD when it was turning, and when it would stop turning the belt was just sliding over it. It this a common part to go? Anyone have one they would sell real cheap? Tapper SEE PIC BELOW Last edited by TapperManor; 03-22-2003 at 03:57 PM. |
pic
Hmm.. looks like the idler assy below the compressor. It's not too pricy. What about yer parts car?
edit: nice pics... |
Hmm.. I wouldn't say head gasket just because of no heat... needs further diagnosis. You could always leave the AC belt off and drive the '92. Don't think we'll need AC soon.
parts ---> http://www.subaruparts.com/diag/?mod...ategory=732A-1 |
That is why I am driving the '95', to further evaluate its condition. Maybe it is the heater core? On the '92', Are you saying I could just leave the belt off and drive it, temporarily? Tapper |
Hmm... Sure, the belt only drives the compressor. It does run behind the Alt/PS belt on the crank pully 'tho so it's a task. . Boone
... or if it's beat... just cut it. |
The idler pulleys go bad, Worth while to replace around 100k or so.
If you got no heat, check the hoses to the heater core in the engine bay. The heater core may be by-passed if it was leaking. |
