Stevebsy's 5MT swap thread, Start date 8-4-2019
Finally I'm making some progress.
Just picked up a 06 Saaburu 2-5X Aero with hail lumps and a 3 cylinder engine last night. This is great because I'll have every part I should need to make this happen! The transmission is the 3.7 ratio w/ .738 5th gear ratio, so it should turn about 2768 at 75 MPH. Let the fun begin! https://www.dropbox.com/s/l622npnp74...2108a.jpg?dl=0
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 08-04-2019 at 01:02 PM. |
Re: Stevebsy's 5MT swap thread, Start date 8-4-2019
Unrelated, but is it just me or the front left wheel has a chunk missing?
Looking forward to seeing it finished!
Wheeeeeeee
just a year later update: 5MT is in car, attached to engine Pedalbox is in Engine was resealed, new HG, etc.. when I had everything out. Tonight I got back at it again after a long absence and started reconnecting the engine accessories. Remaining items: MT trans. mount fabrication Extend shift rods Remove AT shifter, install MT one Hook up and bleed hyd. clutch Sort out wiring mods required for NSS, etc.. Build new exhaust system to replace currently hacked together one. Since one seat is out, remove the other one, then pull carpet and power wash so it isn't so nasty. 30th anniv. meet should be attainable lol
Progress! Great to hear.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Update-
Shifter linkages extended today, took a couple tries to get it perfect and centered in the AT shifter trim opening.. Picked up a 2000 Outback MT drive shaft, so that will save a lot of work as it supposed to bolt right in and work. Tomorrow will finish weld the linkages, paint them, then look at fabricating the trans rear mount. I've got the parts from the donor car, hoping I might be able to use them to reduce fabrication, we'll see....
