Old 02-05-2008, 03:12 PM
Originally Posted by Trevor View Post
Again logical but,
The line pressure is set and controlled and unless the pressure falls below optimum, pump speed will not affect the issue, unless a fault is causing inadequate pressure. Furthermore the increase in pump speed with the different gearing will be marginal.
The overall answer is to always drive in third unless at highway speed. This results in less load on the friction components, as per Joe, higher pump speed, as per Tom, and very important, no hunting up and down 3 -4 at low speeds.
again I lack the ability to post my thoughts correctly. I was meaning to say that the low line pressure is a cause for dying transmissions, this is due to pump gasket failure and also leaks both internal and external.
The higher gear ratio allows more flow, not more pressure... I hope this is making sense??
Old 02-05-2008, 03:25 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Steve, if you are free I could probably stop in on either Sat or Sunday pm around 3ish and see if it might be something simple. Lord knows I don't want you to catch Hocrest. I'd have to poke fun of you instead if that happened! Send me a pm prior to Friday evening with directions off 83 and a phone number if you'd want me to stop in.
Old 02-05-2008, 05:00 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
You all make valid points. Here is the history of this tranny.
This is the original SVX transmission. I went out about 3 months into me buying the car. I saved it in hopes of rebuilding it into a spare. When I was in Minnesota I had my 3rd tranny go bad. I took the SVX and the original SVX tranny to a shop. They rebuilt the SVX tranny and transferred the front diff and long pinion out of the 4.11 into the SVX tranny making it an SVX 4.11 transmission.
I drove on it for about a year and it started to fail. I had a local shop and a master Subaru tech rebuilt the transmission. It had never ran better. I felt that it would last forever. silly me.
After talking with him today i have changed the fluid and it is running better a lot less flare but it is still there. I also found out that my original valve body was shot and he replaced it with a known goo one. It sound like the valve body is starting to go. Once in gear the car runs great. It does not slip out.
So in short the internal guts are stronger that a stock 4.11. only the final drive is from a Impreza. The external cooler is disconnected the mechanic might be hooking it back up soon. It is under warranty so what he say kinda goes.
Will a valve body out of a 4.44 work in the SVX tranny with 4.11?
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 02-05-2008, 05:03 PM
SVX-FF's Avatar
YT, I may be looking for a u pull it tranny and parts. (student budget)
Ben, I have my daughters 3rd birthday this weekend so it might not work.
Thanks to all for the info.
I am starting a collection that will rival Earls. I just need the cars to go with the trannys
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 02-05-2008, 05:27 PM
Steve
Steve, my observations which may help.
“I also found out that my original valve body was shot and he replaced it with a known goo one.”
A bad, bad, bad. A new set of solenoid valves should have been fitted, or at the very least everything cleaned and solenoid A, which has an arduous life, replaced.
“It is under warranty so what he say kinda goes.”
---- and surely he has to honour the warranty and fix it.
Old 02-05-2008, 06:08 PM
benebob's Avatar
Steve
I'm up there every Sat and Sunday so any weekend I should be able to fit it in. Hope she has a great birthday!
Old 02-06-2008, 08:20 AM
SVX-FF's Avatar
Well it was a little over full not by much. There is no more smoking, smell is lingering.
What is anyones take on Level 10 transmissions?
If I can break one of theirs do I get a medal or just baned from SVX's?
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 02-06-2008, 01:09 PM
Steve
Punting for a medal, eh? What next?? A PhD in destruction!!
I have no first hand experience but I have faith in their approach.
Phil [b3lha] had his Level 10 upgrade. It cost megabucks because of shipping. It eventually failed, but he had not put the extra transmission cooler in the circuit, and he really should have done.
I say eventually, he put intergalactic miles on it.
This time around he has put a cooler on the system. He'll probably get 200K onto this transmission.
