Old 01-27-2008, 11:19 PM
Lightbulb carbon fiber wrap sway bar??
i havn't worked with carbon fiber yet(looks like a similar process to FG), but maybe someone here has. i was watching a little piece on tv about carbon fiber being used for stiffening structures and i got to wondering if this could be applied to our sway bars? now i know it sounds unlikely but from what i saw, it might just work and be able to be done at your own home at a fraction of the cost of getting costom ones made. the fronts seem problematic but the rears might work pretty easily. does anyone here have experiance with structural carbon fiber wrap that can put this into perspective?
Old 01-27-2008, 11:24 PM
Hondasucks's Avatar
Subaru Technician
I don't think it'd work for a sway bar since there's too much twist/flex, it'd crack.
1986 VW Jetta
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
I dont think Carbon Fiber would help with torsional rigidity?
-Dustin
Old 01-27-2008, 11:45 PM
subbieatnz's Avatar
aircraft type allumium wuld be better ???? if you could afford it
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 01-28-2008, 12:04 AM
it should help with the torsional rigidity if you wrap end to end. stiffness is one of it's main characteristics.
the big question is will it crack? this is where we need someone with experiance. think about some of the cf aplications these days, wheels, strut bars, frames, axles, bodys, masts(boats), everything for race cars and high end street cars, pretty much anything you want to make stronger, stiffer, lighter(like our sway bars).
Old 01-28-2008, 12:30 AM
odepaj's Avatar
Killer of threads
IDK, maybe im having a huge brain fart right now. But I really don't see how carbon fiber has torsional strength.
Dustin
-Dustin
Old 01-28-2008, 12:42 AM
they wouldn't make driveshafts out of cf if it didn't have torsional strenght.
Old 01-28-2008, 12:49 AM
odepaj's Avatar
Killer of threads
Ahh good point.
-Dustin
Old 01-28-2008, 12:57 AM
just did a search for carbon fiber torsional strength and came up with many places saying it has 3 times the ts of steel!
Old 01-28-2008, 08:55 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
The issue you're going to have with a sway bar is that it has "arms", unlike a driveshaft. CF will work if you go with a three piece set up, but then you've got issues with putting splines on the end of the main bar so it engages with the arms.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-28-2008, 10:40 AM
dcarrb dcarrb is offline
Carbon fiber may indeed have torsional strength but I don't believe you'll find it in many applications where repetitive flexing is required. You want springiness, not rigidity. And if you wrap a sway bar with the stuff (as the 2x4 was wrapped in the TV show cited, "Smashlab,") I suspect it will de-laminate from the steel in a hurry.
dcb
Old 01-28-2008, 11:30 AM
i wonder if shaving off 6 flat spots around the bar the whole length(if you took a vertical cross-section it would look like the hex head of a bolt) useing a grinder would keep it from delaminating?
as for the repetitive tension, i would think that a cf control arms are subject to similar forces. also cross braces for airplane wings.
Old 01-28-2008, 12:38 PM
odepaj's Avatar
Killer of threads
Those types of things dont go through the same flexing as a sway bar.
-Dustin
Old 01-28-2008, 01:00 PM
i found cf sway bars for quads, but of course they weigh much less.
doesn't anyone have experience with this stuff, we need some kind of expert here to give us some concrete facts.
Old 01-28-2008, 02:38 PM
SVXRide's Avatar
I would love to see any CF sway bar that exists. My engineering training (and limited experience with CF) tells me that a single piece CF bar just won't work, given the inherent loading the bar sees and the inherent performance characteristics of CF.
-Bill
