Old 01-26-2008, 02:16 PM
BenSVX BenSVX is offline
Fuel Injection Flush
My car needed a boost yesterday to get started, so I took it to the local shop to test the battery and see if I need a replacement (it tested "good" so I'm holding off for now).
The mechanic, however, said I had a slightly rough idle and asked if I had ever considered a fuel injection flush. He quoted me $89.99 (just for me!!!) for the flush. I said I'd take it under advisement.
So...any advice? Is this worth it? Will it save on mpg and idle any smoother?
Thanks!
Ben
92 Graphite LS-L Touring (136k miles) #4143
5 speed, ACT clutch, Sparco R-Speed shortshifter, Ecutune v1, Stebro exhaust, PWR rad, 18" Motegi Racing FF15 wheels wrapped in Falken Azenis, Alpine 9833 MP3/CD with Alpine 3ways in front, MSW G-lateral drop springs, ss braided brake lines, d/s rotors, 9005 headlight mod, Celcius mod
92 Ebony LS-L Touring (125k miles) #7328
smallcar shift kit, Panasonic MP3/CD, Remote starter with security
For Sale: http://www.subaru-svx.net/forum/show...370#post501370
92 Claret LS-L Touring (Sold - 1998)
The first car I ever drove.
Old 01-26-2008, 03:27 PM
Mission Mission is offline
It does increase fuel mileage, smoothes idle and restores lost performance but there are cheaper and equally effective alternatives. If that really is the issue check your fuel filter if you havent changed it, try Chevron Fuel System Cleaner because its the best, also if it is cold like it is here in Alaska dont run your gas tank past half or condensation will build up diluting your fuel with water giving you a rough start and idle so try some Heet Yellow or Red Bottle.
Old 01-27-2008, 01:26 PM
dennyo dennyo is offline
You may want to clean the throttle body's and iac while your at it.I don't think mine had ever been cleaned and when I took it off to clean it inside it looked like a blacktop road in there check vac lines too.
Old 01-27-2008, 05:06 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Do it yourself -- SeaFoam with a piece of vacuum line from the can of SeaFoam to the vac tap that the FPR uses (okay to disconnect the FPR while you're doing this) and then run the engine until you've used up the amount called out on the can. Then disconnect the snorkus from the TB and clean the TB out with regular carb cleaner (do not attempt to have the engine running when you do this, as it needs the airflow through the MAF...). Make sure to open the throttle plates so you can clean the inlet all the way through where the plates seat.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-29-2008, 11:55 AM
Nevin's Avatar
Nevin Nevin is offline
While this is an important thing to do every once in a while, I would say it is by no means worth $90. As previously stated, just do it yourself with a can of Seafoam and you'll be enjoying miles of smiles in no time.
Jesus is the remedy
2015 Expedition EL Ecoboost
