Old 01-25-2008, 12:04 AM
subbieatnz's Avatar
Diff removal and replacement on svx
Hey
just wondering the best way to do an Diff removal and replacement on svx?
i just never done much work on an svx so just want to no whats involved?
also are all svx diffs the same ratios... ( i mean stock svxs lol )
Thanxs
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 01-25-2008, 07:26 AM
Hi Subbie
Do you mean the front diff, rear diff, or both?
I have never done any work on them, but by all reports on here it is do-able.
On top of the page you will see "Old Lockers" Go into the locker of svxfiles. He has a picture or two in there. Have a look at the pics he has about a diff swap. [from standard US to 4.44]
Regards your question the USA got final drive of 3.54, which is a very high overdrive to suit their long highways.
All the rest of the world got 3.70, so your JDM and NZ models should be exactly the same.
[If you are still unsure, if you PM Tom [svxfiles] he will tell you what to watch for]
Old 01-25-2008, 07:32 AM
Here's the basics;
- Undo the 4 drive shaft/flange bolts
- Use a pry bar to "pop" the rear axles from the diff. You won't be able to completely remove them yet, just make sure they are free.
- Remove the two nuts on the rear studs of the diff
- Remove the 6(?) bolts that hold the front crossmember/nose of the diff
- As you lower the diff, you should be able to get the axles the reast of the way out.
Old 01-25-2008, 04:57 PM
subbieatnz's Avatar
thanxs you
1983 RX Silver Grey
Old 01-25-2008, 05:22 PM
One thing I forgot, the exhaust may want to get in the way as you try to lower the axles. You can work around it, or drop the midpipe also.
