Old 01-16-2008, 11:33 AM
Wikedjuggalo's Avatar
Rebuilding
Need some Sub Information
O.k I am getting my Sub and Amp and wanting to compile a How-To on an install, but I am still wondering on where to run the power wire, if anyone has a picture of where they ran it I'd love to know ^^
Old 01-16-2008, 01:26 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I ran mine through the hole on the passenger side where the evaporator hose goes through.
The other area you can run it through is where the pedals are drilled through the firewall
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-16-2008, 01:33 PM
94SubieSVX's Avatar
OOC for a while
There was a 1/2" hole kind-of down and to the left of the brake reservoir(looking from the engine bay into the car).
And the power wire ran along the firewall(now inside of the car) and down next to your left foot kick panel.
Then it was underneath the white plastic brake line protector piece. (I think its the brake lines??)
The power, and remote wire went through there for my setup.
bLAh
Old 01-16-2008, 02:28 PM
Rebuilding
I think this will be my best route going out there now to attempt this ^^
Old 01-16-2008, 04:44 PM
94SubieSVX's Avatar
OOC for a while
I forgot to add that once it's passed the white protective piece, it just went underneath the back seat and into the trunk.
I'm sure if you wanted it to be better looking you could run it up through the trunk liner and have it drop down through one of the speaker holes, or the Security Module hole.
bLAh
Old 01-16-2008, 07:44 PM
redlightningsvx's Avatar
Collision Refinishing Tech
i ran mine through the driver fender, into a grommet that has a yellow covered wire going into it, then it comes out behind the kick panel and run it underneath the carpet straight back.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-16-2008, 08:23 PM
Rebuilding
Its now around 10:30 I finished I'm so freaking tired. I will do a write up tomorrow, funny thing is those the plastic pieces around the rear speakers split from the sub and stuff.... Guess thats good ^^
Old 01-16-2008, 09:42 PM
94SubieSVX's Avatar
OOC for a while
Pretty much any SVX you see will have split speaker grilles. It's just one of those things
bLAh
Old 01-16-2008, 09:49 PM
little late, but for reference
here is where I found to be the most direct route for running a pair of 4ga wires to the rear of the svx.
1: running power out thru the fender
2: inner fender side pic (other side of batt)
3: going thru rubber boot into drivers kick panel
4: wires inside car by factory fuse box, go to fuse block w/ 2 4ga in and 4 8ga out w/ 4 60 amp fuses (running 2000W RMS between 2 amps)
5: going back to truck under rear seat pivot
blk 92' LSL w/ average mods
Old 01-17-2008, 04:53 AM
Rebuilding
They weren't split before I put it in >.<
Old 01-17-2008, 03:02 PM
94SubieSVX's Avatar
OOC for a while
Ooohh...well in that case you must have some decent bass goin on
bLAh
Old 01-17-2008, 07:17 PM
This is how i did mine and it came out very clean looking when i was done
Seth
Past subies:
Other toys:
Old 01-17-2008, 08:12 PM
more pics (I have about 90 from the install, just waiting to do the write-up)
1: RCA's at the head unit
2: fuse block installed next to the the factory fuse block
3: in the middle of it all
4: trunk done
5: door w/ 3M insulation
Old 01-17-2008, 10:07 PM
Rebuilding
4: trunk done
I beat you to it ^^
gotta find out how to submit it, I used the passenger side to do mine. Your is different you should write one up
