Old 12-31-2007, 01:27 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Again
Originally Posted by kwren View Post
Naturally it will only punch out one direction. The alignment on the shaft and the part out of the transmission must be the same when reinstalling the pin. In otherwise you could slide the 2 components together 2 different ways 180 degrees different, when reinstalling the pin but only one way will work.
Drive the pin up to remove it, making sure proper clearance is available to drive it all the way. the shaft can easily be turned by hand if needed.
Get a good punch and a good heavy hammed and smack it. Baby tapping it will just swell the pin.
Good luck,
Keith
LOL--again. I think you should look at a NEW roll pin. I suspect you will see that it is the SAME diameter for the full length. It compresses slightly to form a tight fit in the hole. However, one end does frequently get spread or beatup by improper installation or removal tools.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 12-31-2007, 05:46 PM
kwren's Avatar
kwren kwren is offline
LOL... right back at you!
that is what I said. Can only drive it one way. Just trying to make life easy!
Old 12-31-2007, 07:36 PM
boostinsidewayz boostinsidewayz is offline
lol, i took the pin out both ways. i ended up pulling the trans stub shaft out still attached to the axle, then broke the punch trying to get the pin out. then i used another thinner punch to punch through the pin, and drive the the other punch out. then i used a drill bit to pull the pin a little bit. blah blah blah, then i finally got the stupid thing apart. got it all back together, test drove the thing. this thing is amazing. i love driving it.
Old 12-31-2007, 10:44 PM
crazyhorse's Avatar
242,000 mi on oem trans
Makes the aggravation worthwile huh?
"42"
Current Stable By Age:
Old 01-01-2008, 03:28 PM
kwren's Avatar
Sorry, sorry, sorry
But I counted 3 ways!
