Old 06-10-2005, 01:21 PM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
Where's that coolant coming from?!?!
He guys,
I was driving home this morning on the freeway and look to see my temperature gauge almost pegged! I pull over expecting a main radiator hose leak, but no. It seems like it is coming out from under my intake manifold on the drivers side it appears. So I proceed to drive 30 miles in 2 hours stopping at every gas station to check water level and to let it cool off. I got it home but now I don't know where to start, I'm thinking of pulling off my intake manifold. Any help would be greatly appreciated, thanks guys and gals.
Steve
It's not a car..it's a boat!!
Old 06-10-2005, 01:33 PM
dcarrb dcarrb is offline
The coolant channel for the ECU and temp gauge sending units runs beneath the intake on the driver's side. I'm thinking maybe a heater hose connects under there, too; would have to check.
I'd let it cool and give it a long look before pulling the intake.
dcb
Old 06-10-2005, 02:17 PM
red95svx
Yes. It's a metal pipe that carries coolant from one side of the block to the other. Rare to see them leak.
Old 06-10-2005, 02:39 PM
Make sure you check the hoses because you can easily miss a pin hole leak that will only show up when it is on the road. I just had that problem and almost missed the leak.
Old 06-10-2005, 02:49 PM
I remember looking at that thing when I changed the ECU sending unit and thinking man, I hope that never leaks.
dcb
Old 06-10-2005, 08:28 PM
THAWA
hoses are more likely to leak, you've got a lot of coolant flowing on that side of the engine, heater core hoses, tb hoses, iac valve hoses, etc.
Old 06-10-2005, 08:42 PM
Heater
Hmmm, when I was doing my 20 mph in the slow lane I had my heater on. It was working intermittently so that could be it. Does anyone know any easy way to access the hoses under the manifold?
Steve
Old 06-10-2005, 08:48 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
The only coolant line under the intake that you can get to without removing the intake are the ones that provide the "heating" to the throttle body (check the "throttle body bypass" thread for pics). I hope it is one of these hoses, otherwise you've got some serious work ahead of you...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-14-2005, 08:16 AM
Wierd
Ok, I checked the lines after startup and no leaks. I waited until it got to operating temp and then drove around in second to keep the rpm's up, and again no leaks....my car is possessed. Any ideas on what is going on? Does the pressure in the cooling system increase enough at highway speeds to make something leak so massively and yet not leak at all other times?
Steve
Old 06-14-2005, 04:10 PM
SVXRide's Avatar
Steve
Steve,
did you top the coolant off before driving it around? I'd try to recreate the same conditions as you had when it leaked last time.
-Bill
Old 06-14-2005, 06:40 PM
Coolant
Yeah,
I filled it up, with just water of course. I'm going to take it on the freeway tomorrow when I get home from work and see what happens.
Steve
Old 06-14-2005, 07:52 PM
SVXRide's Avatar
Yeah,
Steve
Steve,
Two things:
1. Check for bubbles in the radiator before you let it warm up (just remove the radiator cap and let the car run)
2. Check into getting some dye to put in the radiator - it helps show where the leak is - if you actually have a leak
-Bill
Old 06-15-2005, 08:12 AM
Svx
Well I filled it with the car running and no bubbles. I just don't get it, I mean this thing was leaking bad and now nothing? I'm scared my car is going to strand me in the desert.
Steve
Old 06-15-2005, 10:02 AM
914helo 914helo is offline
That does sound like a hose leaking. Being on the driver side, it could be #12 in this diagram from the water pump to the water pipe. I just recently changed mine when I had my engine on a stand. In the car, you'll have to remove some stuff. Good luck.
Kent
Old 06-15-2005, 11:50 AM
Rotorflyr's Avatar
If your going to be driving thru the desert, make sure you have the pirate hat and eye patch on, like in your avatar, so when we find the bones we know it's you!
2006 B9 Tribeca
