Oil Leaking...........stillllllll!!!!!!!
After my $3000 (+) head gasket job, I just noticed I'm getting oil leaking (again) from my engine....onto the driver's side catalytic convertor (sometimes creating a minor smoke billowing situation!).......YIKES! I replaced every gasket and seal I could think of...evidently I overlooked at least ONE! Seems to be coming from rear driver side of engine...???? Is there anything in that area that could explain such a mild to moderate oil leak (which sometimes ends up dripping onto the top of the driver's side catalytic convertor...causing ANNOYING SMOKE!) [It's dripping enough so that in 2 weeks, I've accumulated a 5 to 6 inch diameter oil spot in my garage.]
Please speculate on the source of this leak..... THANKS!
Are you sure it is oil and not trans fluid? Mine had a mild leak in that area which progressed into a severe leak. There are two lines for trans fluid to travel to the cooler and back. Between the engine and transmission there are hoses and if the clamps come loose they will leak ATF all over the drivers side cat.
These clamps can be a pain to get to, the one that was causing most of my problems couldn't be seen, I had to find and tighten it "blindly" If it is oil though, my guess would be valve cover gaskets...
Leak!
I'LL CHECK!......Thanks!
Rear Cam Seal. My car did the same thing. I switched from 10-30 dino oil to 20-50 dino oil and the leak basically disappeared.
Is it really wise to put heavier oil like that into our cars?
ohh..... well he has a legacy.. but still. |
Only source of oil leaks on the rear of the engine is the rear main seal (crank seal). In any event it is better to fix the leaks than put in a heavier weight oil.
sorry do not mean to tread jack. i justreplaced my valve cover gaskets. and there is still something leaking from the back of the motor. i get smoke at stop lights from rear of the motor
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
