Old 03-18-2003, 04:07 PM
kuoh kuoh is offline
I beg to differ. I've seen H3 bulbs installed incorrectly and the clip forced on so that it actually touched the postive base of the bulb and shorted out the circuit. Also since the bulb is able to ground at virtually the entire perimeter of the seat, it is possible to have a bent seat or have some sort of foreign material get between the seat and the frame causing the bulb to be slightly tilted, yet grounded where it can still illuminate.
There is no such thing as an idiot proof system.
KuoH
Originally posted by svxcess
[B]The stock H3 bulbs are impiossible to seat incorrectly. They only go in one way and the metal spring clip which holds the bulb in and provides the ground will not fasten under the notch if the bulb is not seated 100%.
Old 03-19-2003, 09:20 AM
My assumptions were made on a bulb that was not deformed in any way or without any foreign material between the bulb seat and frame.
If you take out the burnt bulb and put another one in there should not be a chance for foreign matter to get in. A properly manufactured bulb should just slip right in and the spring clip should lock without difficulty. If you have to force anything to fit then there is a problem.
Old 03-19-2003, 10:41 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Originally posted by kuoh
Unless the bulb is incorrectly seated, I don't think there is a way to adjust the aim of the fog lights independently from the other lights. The aiming assembly in the SVX adjust the entire unit.
KuoH
check the rotation of the bulb and the metal latch thingy, if the bulb is not properly seat and jammed in there it culd be making a wierd light pattern. This happend to me when i got my car, little rotation and it went right into place.
phil
~Phil
